Question about Garmin StreetPilot c340 GPS Receiver
Karen died doesn't work when plugged in, only when on battery alone
  • Garmin Master
  • 2,130 Answers
If the unit works on battery but not the AC adapter or cigarette lighter adapter, obviously the problem is in the adapter.
1. Have you verified that you have +12VDC at your accessory jack?
2. Have you checked the fuse in the cigarette adapter?
What are you powering it with when not on the battery?
- Jim
Posted on Feb 15, 2008
The horn on my Pontiac g6 doesn't work along eith the key fob but everything else in the steering wheel works
Horns are not in a good place on the car as they are just inside the front grill with the wind, salt and water. Check it by attaching two wires to the battery and touching the contacts on the horn.
You are not alone, it is a known problem!
horn on my Pontiac g6 doesn work Google Search
Feb 19, 2018 | Pontiac Cars & Trucks
I have a lenovo thinkpad T420 and three days ago I lost my power cord now that I got a new one my laptop screen doesn't seem to turn on I tried a lot of solutions and nothing seems to work. When I turn...
Hi, try removing the battery pack then use the AC adapter or power cord alone. If still the same. Eject the battery and also remove from outlet hang on for 10 minutes. Then try to turn it on again with AC adapter alone
Oct 06, 2012 | Computers & Internet
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
It doesn.t respond I can,t accesse t the menu and Ican't make photos
Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 11, 2009 | Panasonic Lumix DMC-LZ1 Digital Camera
CDM-8915 PHONE IS DEAD!
The solution: I left it alone for 24 hours.
Here's what I did:
I plugged the charger in and allowed it to charge overnight. No lights or screen or screen appeared but I kept it in anyway. After charging, I removed the battery and cleaned all the contacts with Isopropyl rubbing alcohol. When I reinserted the battery, it vibrated intensely, which indicated a strong battery. I did not turn the phone on right away but waited a day. When I turned it on, it responded like nothing was wrong. Perhaps the phone reset itself. That’s how it behaved.
In any event, I have my phone back and it’s working well.
To summarize what happened:
The phone drops into a puddle and is partially submerged for an hour or so. I find it, dry it off and make some calls, with no effects of any kind.
The next morning, it fails completely. No response whatsoever. I recharge the battery and that doesn’t work. What did work was to remove the battery and clean all the contacts and reinsert it and leave it alone for a day.
Lesson learned: record all phone numbers before I lose them forever.
Also, get a better holster so that the phone is secure from falling out.
Thank you very much for your support.
Bill
Nov 07, 2008 | Audiovox CDM-8915 Snapper Cellular Phone
Losing Wireless Connectivety, when charging.
Try to plug in the power cable alone, do it without the battery and see if your wireless works.  If your wireless works without the battery, and works with the cable alone it may be a battery conductivity problem.
May 25, 2008 | Acer Aspire 5100 Notebook
Clearing memory
WELL, After a year I alone, without any help from UNIDEN, FIGURED IT OUT.
1. TURN IT OFF, UNPLUG AC JACK IN THE BACK!
2. REMOVE Backup battery cover "underneath" scanner! TAKE ALL 3 BATTERIES OUT.
3. I PUSHED THE POWER BUTTON TO BLEED ANYTHING OFF IN THE CAPACITORS, IF IT HAS ANY INSIDE?
4. PUSH THE"2", "9", AND "HOLD BUTTONS DOWN, THEN PLUG THE A.C. BACK IN ON THE BACK OF THE SCANNER.
5.You WILL notice while you are doing STEP#4 THAT THE DISPLAY SAY'S "CLEAR". ALL FREQUENCIES WILL BE CLEARED IN THE MEMORY!! THEN TURN Scanner OFF reinstall the BATTERIES, TURN BACK ON AND START PROGRAMMING!! THIS WAS FOR A "BC340CRS" SCANNER
Mar 28, 2008 | Uniden BC340CRS Base Scanner
Garmin StreetPilot c340 GPS Receiver Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
