Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The volume will not go up or down
The tv has sound and a picture, but the volume will not turn up or down
    Sergeant:
    Champion:
  • 346 Answers
Are you using the remote control? if the remote switches the tv on and off then it will also turn the volume up and down
Posted on Feb 18, 2008
  • 21 Answers
Make sure theres batterys in the controll.
try turning it up from the buttons on the tv.
else i dnt no
Posted on Feb 15, 2008
3 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 17, 2008
SOURCE: SONY KP 43T75 TV PICTURE WORKS SOUND IS ON FULL
the remote control buttons were stuck
Posted on Oct 09, 2009
How do i fix volume problem , i have samsung 46 inch lcd , picture working fine but no sound?
Hi is your television running through a foxtel box or something else that has volume control, If so you might have one or the other turned all the way down, turn both volumes up and control every thing through one remote control.....
Mar 15, 2016 | Samsung LN46B550 46 in. LCD HDTV
Samsung plasma tv #pl42b430p2d volume turn up &down itself
hi the v+ is dirty or just bad maybe every taster
Nov 26, 2013 | Televison & Video
Tv has power but no picture or sound
your volum might have blown turn it off and give it time to cool down if that doesnt work you may have to get a new tv also check you volum settings and mute
Jan 11, 2010 | Televison & Video
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sound
WOW never heard this one . You might check the volume down button on the tv to see if it is depressed in . What is the model # and do you clean the picture tube with windex ? Maybe some of it has seeped down onto the control board and has gummed up the volume down button. Good luck
Mar 03, 2008 | Sony KV-27V42 27" TV
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Rca 32v524t chassis-atc010a
This sounds like something best handled by an experienced tech since the fix involves extreemly high voltages nearby,
If you have a very good knowledge of the inner workings of tv's then ask for more information.
Nov 21, 2007 | RCA TruFlat 27F520T 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
