Question about Motorola Mobility V360 Cellular Phone
To solve motorola v360 storage device
I got a trouble in my cell phone(motorola v360) it says"storage device unreadable" if i press the memory card it says to format, but if i press ok button is going to formating FAIL
  • Anonymous Apr 13, 2008
    we put songs on our memory card off the computer.
    now when we go to sounds, right to the bottom were it says memory card. we click it then it says storage device unreadable so we press ok.then it says formatting will erase all data continue? we press yes then it says formating failed try again .what do i do?
  • Anonymous May 16, 2008
    MY CELLPHONE MEMORY CARD SHOWS AS UNREADABLE FORMAT WHEN I AM TRYING TO FORMAT IT THEN FAILS
I had the same problem if your memory card is over 150mb then it is to high a memory for your phone you can buy a 150 mb memory card in your local phone shop
Posted on Oct 06, 2008
I dont think that will work...
Try Compressed Air and clean slot, and card... xD
Posted on Apr 15, 2008
    President:
  • 778 Answers
Take a pink pencil eraser and clean (by rubbing the eraser on the contacts on the storage device and see if that doesn't cure your issue?
Good luck.
Posted on Feb 15, 2008
I cant reformat my phone memory in my motorola w388, i try to follow the steps to master clear but it still unable to work. is there something i can use to reformat my phone memory??its getting worst
hi!
All you have to do to reformat the memory card is that you have to
insert the memory card, press the Center Select Key,scroll to and select Phone Status, scroll to and select Device Info, scroll to and select Storage Devices,select Memory Card and press Options, and then select Format.When prompted, press Yes to continue or No to cancel formatting.
Another step for you to be able to reformat your memory card is you just have to
press Main Menu,scroll to and Select Settings,scroll to and Select Storage Device,scroll to and Select Memory Card,scroll to and Select Format Memory Card, and then
highlight Yes and press the Center Select Key.
And this will also be an option for you to format your memory card.Here are the steps:
Insert the microSD card.
Press Menu > Settings > Security.
Enter your lock code.
Select Format External Memory. (A warning will be displayed.).
If you are sure you wish to remove all the files from your microSD card, select Yes (left softkey).
Thanks!
Apr 17, 2011 | Motorola Mobility W388 Cell Phone
"Storage Device Unreadable. Format Now.?"
yes there is a possible solution to your problem....there seems to be a problem with your card....and it doesn`t look like you can get your data back from it ...so you will have to format your memory card....connect your card to a computer through a memory card reader by also using your micro card`s adaptor and then format it from your computer......hope this helps.....please vote ...help us to help you better
Aug 07, 2009 | Motorola Mobility V360 Cellular Phone
Motorola V360 -Memory card slot error
Hai Dud,
Are you using Micro SD transflsh memory??
Format the Card on the PC using FAT, after that use a CARDREADER and put these folders on the card: MOBILE and in the mobile folder put audio, video, kjava, picture, temp! Shutdown your Motorola, remove the backcover and plug-in the card! After that Start Your Motorola and copy a file from the mobile's memory on the CARD! It should work!
Hope it Helped You,If so give an "High Five!" [;)]
Aug 04, 2009 | Motorola Mobility V360 Cellular Phone
OMG!!
your memorycard is corrupt or virush.then scan your memorycard otherwise replace it.
Feb 04, 2009 | Motorola Mobility W230 Phone US with...
ADDING PICS AND RINGTONES FROM MEMORY CARD TO PHONE CONTACTS
there is an internal sim card that has 1GB already in the phone. you want to do is switch the storage device on the phone.
press options>switch storage device>select
press details see where the card is and how much is left on the right card.
to copy or move a file from your phones internal memory to the memory card, open a file list such as pictures and press options
scroll to manage and press select
scroll to copy or move and press select
memory card is highlighted. press the center select key.
when you are in camera mode
hit options and select storage device
select the desired option and press the center key.
remember to hit details.
Jan 23, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Memory card
just put it in the slot...
May 15, 2008 | Motorola Mobility V360 Cellular Phone
Getting music from memory card
Hey Green-e,
I think ur problem is lack of knoledge to identify the type of data storages device.
There are two types of storage devices: 1) MMC(memory card)
2) Phone memory
When u enter menu->multimedia->sounds, there is a list of sound tracks, ringtones, etc.
In ur cellphone, u may have used Phone memory or memory card as default storage device. If u hv used phone memory, then change to MMC and if u hv used MMC, then change to phone memory.
TO change the storage device.
In sounds (where sounds,ringtones, appears), press menu button (above directional keys). Now u will see a list of options. There u can see storage device. Press on it and change it as u want (MMC or phone memory).
Kindly send me feedback and rate my solution
Be sure to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
May 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
My slvr
Did you use the phone to format the media card?
Do you have the USB data cable to attach it to a computer?
Do you use Moto Tools software on the computer?
Email me at mewms_14904@verizon.net
see and change
memory card information
Find it: Press - > Settings > Phone Status > Storage Devices
1 Press S to highlight the memory card.
2 Press the Details key to see the memory card information
or
Press - to see the Storage Device menu, which lets you
Format or Rename the memory card.
Mar 02, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Memory card problem with motorola v360
Try to format it via a memory card reader by your computer. Good luck!
Sep 13, 2007 | Canon PowerShot A95 Digital Camera
Motorola Mobility V360 Cellular Phone Logo
196 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
