Question about Konica Minolta DiMAGE A2 Digital Camera
5600hs or 3600hs equivalent in other brands
Hi.
I'm trying to find a good and affordable flash that would be the equivalent of either the 5600hs or 3600hs. I have an A2 digicam and Maxxum XTSi and ideally, I'd like a flash that I can use with both cameras.
I've found a Bower brand. Is it any good?
Thanks for your help.
    Brigadier General:
  • 3,006 Answers
I live in London, England, and have never encountered the brand you mention. However, I can recommend the Metz 48-AF1; it has a Guide Number of 48 and does pretty much everything that the 5600hs and 3600hs do at far lower cost, including the wireless flash which the A2 can work with. It also makes sense as it can be changed to fit any major brand by adding the appropriate adaptor so is highly resaleable. In the UK the basic flashgun sells for around £155 and an adaptor is around £30 extra, but I've noticed on my travels that it's far cheaper when priced in US $.
http://www.metzflash.co.uk/pages/metz48af1.html
Posted on Jun 29, 2009
Wide angle defuser is broken Minolta 5600hs
It's not a problem if you're not using a wide-angle lens. And if you are, you can always diffuse the flash by putting a thin white handkerchief or even a sheet of tissue paper over the flash.
Jan 10, 2013 | Konica Minolta Minolta 5600HS D - Hot-shoe...
I am looking for manual of minolta 5600 hs d
Here is an online manual for your digital camera:
http://www.scribd.com/doc/22344755/Minolta-Maxxum-Flash-5600HS-D-Manual
Hope this helps!
Remember to Thumb me Up lots for all the hard work! :D
~~Dayminner
Jun 03, 2011 | Konica Minolta 5600HS for Maxxum Minolta...
I have a Minolta 5600HS flash that I have used for four years with my maxxum 7d without a problem until recently. The flash continues to function fine while on the camera and can be set to wireless mode on...
It could be a simple connection that is loose and just need to be put back into position, or it could be a controller circuit that is bad and needs to be replaced. This is not a user repairable problem. It should be sent in for repair.
Jan 20, 2010 | Konica Minolta 5600HS for Maxxum Minolta...
I have a Minolta 5600Hs flash. It's worked great
I would not recommend you fix it yourself since several of the inside componentes are high voltage and dangerous. But, why wont the flash turn on? if the batteries are good, could it be the battery contacts on the battery door and inside the flash? If the batteries have ever corroded (even a little) then that would be the problem. Use a pencil eraser to shine up the contacts until they are bright and shiney clean. Do not use sand paper or anthing vabbrasive as that will cause the contacts to corrod more and the problem will be worse.
Nov 18, 2009 | Konica Minolta 5600HS for Maxxum Minolta...
Cannot get wireless flash mode to work on my 7D
It is not operator error. I had a similar experience and spent days pulling my hair out trying to figure out the problem.
Unfortunately, the 5400HS is NOT compatible with the 7D. Only to 3600HS(D) and 5600HS(D) are.
The problem stems from the fact that the digital cameras cannot to TTL (real-time) flash metering and have to rely on pre-flash instead.
Because of this, Minolta updated the control protocol to include a signal to tell the flash to pre-flash. Unfortunately, only the two newer flashes recognise and respond to this new signal.
I spent weeks trying various things to get around this, but with no joy. Sorry to be the bearer of bad news, but your 5400HS just will not work properly with the 7D either wirelessly or when attached to the camera.
Matt.
Mar 01, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Startup problem
I have the same problem with this flash. In a couple of days I'll find out what's wrong with it, and write here.
Sep 19, 2006 | Minolta 3600HS (D) TTL Flash
Is wireless/remote flash available?
Yes. Wireless / Remote Flash allows the camera to control Minolta 5600HS(D) and 3600HS(D) flash unit. (sold separately)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
Is the wide converter attachable?
Wide converter can be attached by using the dedicated adaptor ring ZCA-300 and will provide equivalent to 26mm angle of view in 35mm film. The closest subject distance: Normal Recording mode: 70.5 cm (from CCD), 60 cm (from the front of wide converter) Macro mode : 20.5 cm (from CCD), 10 cm (from the front of wide converter) *1 Set the Lens acc. to Wide Converter. in the setup menu. (Optical zoom will be fixed at wide-angle end.) *2 Built-in flash can be used when attaching a filter, but shadowing may occur at the bottom of the image. In this case, use of program flash 5600HS(D), 3600HS(D), 2500(D) (sold separately) is recommended. *3 Filter with 52mm in diameter can be attached to the adapter ring.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta DiMAGE A2 Digital Camera Logo
87 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
