Question about Philips 202P40 22" CRT Monitor
Phillips 202p4 very dark need to make it brighter but at 100 brightness it is still quite dark please send any assistance or advice
    Brigadier General:
  • 6,966 Answers
Assuming no hardware/component fault, the dimness of a monitor signifies near end of life of the CRT (tube).
There are a few tricks/tweaks that can be done but of course these are just prolonging the inevitable. Should you want to give any of them a try, they are:
1. Adjust the Screen controller at the rear of the Flyback Transformer (FBT) to maximum effective brightness. It may also be needed to adjust the Focus control;
2. In some versions, there are sub-bright and/or Automatic Brightness Limiter (ABL) trimpots soldered direct to the PCB that can be adjusted;
3. the heater voltage can be slightly increased either by using a stepdown transformer that has multiple taps about1~2 amps. In some instances, the heater has an external loop around the core of the FBT, adding a turn or so would also serve the same;
4. adding a 100uF/160V capacitor after the diode of the FBT's output that supplies the 3 color drive transistors.
5. use the HV/anode cap of a small monochrome monitor to inject high voltage to the screen grids of the picture tube of the 22" CRT. the heater of the 22" CRT must be temporarily shorted.
All of the above require familiarity and knowledge of electronic components and circuitry, use of a soldering iron and working around high voltages.
If you are not comfortable going through this route, perhaps your best bet would be to seek the services of a qualified professional.
If your concern has not been corrected after completion of the above procedures, you may need to replace the monitor.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 15, 2008
Dark's too dark, Brights to bright?
Monitor Blank hanya dengan warna putih di monitor. bagaimana cara pengatasannya?
Oct 04, 2013 | Sceptre Computers & Internet
My Canon 550d is new and right out of the box on full auto indoor pics are dark. If I go to no flash mode they are much brighter. It's like the flash is out of sync. Is it the camera or me?
the flash only covers a certain range and the built in flash has quite a small range. so lets say its dark in the room and you take a shot of a person they probably look really bright but the background is pretty dark, thats pretty normal and its better not to use flash, now in the auto mode without flash it will be using a higher "ISO" number to get you brighter shots indoors. shots may look slightly grainer but it means its brighter and the 550d handles low light pretty well.
in auto mode you have no control over the ISO but put the camera into P mode which is basically auto but with access to more controls which you can override. now next to the shutter button there is an "ISO"button. experiment with the different numbered setting (100 being low 3200 being high) and you will see what I mean
Oct 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
How can i make my screen brighter?
usually there are keys that you press in conjunction with another key like the Fn key and a key that looks like a bright Sun, or a Dark Sun, shape, on one of the keys usually on the number keys on top row under Function keys. So you press the Fn key and at same time. tap the Bright sun key, and it will step up in brightness, plugging in the adapter also makes it brighter too.
Mar 01, 2010 | Acer Aspire 3000 Notebook
Screen is dark at start up
If its running on batteries the screen brightness will dim quite a bit. If on AC adapter it should be full brightness, but this is adjustable in either case. With the computer up and running, press and hold down the Fn key and push the up arrow to make it brighter and the down arrow to make it dimer.
Sep 16, 2009 | Dell Studio 1537 Laptop
Screen very dim, but set on 100% brightness.
Good Morning! With the 8 years operations of your emachines monitor, some of its electronic parts might incurred cold solder joint connections from its circuit board & possibly some of its Capacitor parts are already worn-out. please try to get assistance from an electronic service technician which will surely diagnose & repair the problem. best regards.
May 04, 2009 | Computers & Internet
Screen is too dark
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness.
Jun 05, 2008 | Acer Aspire 5100 Notebook
Adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
May 26, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Color and brightness problem
Has it been dropped? At first it sounded like it may be have been an intermittent short if the CRT guns, but it's hard to say. Since it doesn't seem to be the cable, it sounds like this one needs component-level troubleshooting.
Jan 07, 2007 | LG Flatron F700B 17" CRT Monitor
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
Philips 202P40 22" CRT Monitor Logo
186 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
