Question about Alps MD 1300 Thermal Printer
Lines through my md 1300 alps printer
Hi I have lines running through my pictures I print out on my md 1300 alps printer, do you know what I can do to fix this?
  • Anonymous Apr 19, 2009
    If you buy a printer MD 5500 for Frank and this develops lines across the print then you are on your own. Frank won't give a damn. Once he's sold you the printer you are on your own.
    Sniper:
  • 58 Answers
It sounds like the head has been damaged. Unfortunately, there is no fix for this, as Alps stopped production of these printers years ago, and now do not offer repairs for these printers.
If you still want a dye-sub capable Alps printer, the only model available is the MD-5500, which you can find here: http://www.alps-supplies.com
Posted on Mar 21, 2008
    New Friend:
  • 83 Answers
Throughly clean the head as described in the owner's manual. A small amount of build-up and cause problems.
Posted on Jun 04, 2010
SOURCE:
My problem is in my Alps MD 1300. Two layers of white print without problems, but when I print CMYK over white horizontal lines appear about ruining my work. I use "white Based (MDC-OPWH)"...
The MDC-OPWH is Opaque White. It's meant to be used as an overcoat when making things like Iron-On transfers when they are applied on dark backgrounds. Regular white is used for undercoating for things like waterslide decals.
May 04, 2012 | Alps MD 1300 Thermal Printer
Alps 1300 printer drivers for win 7
There are no Windows 7 drivers for the ALPS printers. Since you are running W7 Pro, using the virtual XP mode will work. To get full functionality of the drivers, you need to have a motherboard with a built-in parallel port.
Jan 07, 2012 | Alps MD 1300 Thermal Printer
Alps 1300 equivalent
No not for the average consumer/hobbyist for printing white and metallics with an overlay options. There are a lot of options if you are looking for photo quality printers.
Nov 13, 2011 | Alps MD 1300 Thermal Printer
I'm looking for the manual for the Alps MD-1300 printer, I need to know how to print spot colors
The 1300 prints spot colors the same way as the other ALPS printers. To print spot colors, create a mask or layer using only black with your artwork. Select the spot color you want and the black areas on the mask will be printed in the spot color. Make sure that you check the overlay box so the printer retains the printer. You also need to make sure you are using the ALPS printer driver supplied with the printer and NOT the default Windows plug and play driver.
Nov 26, 2010 | Alps MD 1300 Thermal Printer
Horizontal lines in print
Horizontal lines are not good. First try cleaning the printhead with a cotton swab and alcohol. Then run the embedded self print test. There should be a solid black bar at the bottom if the page. If there are lines in the black bar, then most likely your printhead is damaged.
Sep 02, 2010 | Alps MD 1300 Thermal Printer
Cleaning an Alps MD1300 print head
Use a cotton swab and alcohol and gently rub the print head element.
Dec 22, 2008 | Alps MD 1300 Thermal Printer
Alps md1300 lines through ink
Nov 04, 2007 | Alps MD 1300 Thermal Printer
Alps MD 1300
The printers are out of production, and out of support.
Oct 11, 2007 | Alps MD 1300 Thermal Printer
Alps md 1300 only prints in black
First of all, Alps MD inks do not "Dry up". They are dry to start with!
It sounds like you may be running XP, with the Microsoft driver for this printer installed. You need to load the Alps driver, which you can get by joining the alps or alpsdecal group at http://groups.yahoo.com. You can find the driver in the files section of one of the groups.
Oct 05, 2007 | Alps MD 1300 Thermal Printer
Alps MD 1300 Thermal Printer Logo
433 people viewed this question
Top Alps Office Equipment & Supplies Experts
Clive
Clive
defcon000001
Level 1 Expert
Jesse Walters
Jesse Walters
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
