Question about Compaq NX6110 TFT XGA Notebook
Time settings not updating automatically.
When I shut down my computer and restart it again the time settings are disturbed. It was updating autmomatically although the automatic update check boxed is already check.
  • 42 Answers
You says its computer then you have 2 replace the cmos battery which is fixed in the motherboard
Regards
Balisonu79
Posted on Feb 15, 2008
Why does my computer automatically shut itself down on the same day each week.
There are a couple possibilities...first, when you say shut down, do you mean that it restarts, or it actually shuts completely off? Windows update will auto-run weekly and restart the system if necessary. Otherwise, I'd suspect something with your antivirus scanner settings.
Jan 10, 2015 | Computers & Internet
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Laptop date and time setting get disturbed automatically when i reboot my laptop
When you boot up and the Date & Time is wrong then you correct the Date & Time, then when you shut down and boot up again the Date and Time has changed. This is an indication that the BIOS battery is flat and you need to replace the BIOS battery. Install a new BIOS battery, go into the BIOS setting and set the Date & Time etc. and the new battery will keep your settings stored in the BIOS.
Feb 09, 2012 | Dell Inspiron 1464 Notebook
Acer aspire one zge netbook wont update windows
Check the TIME and DATE settings, Set Correctly, then you will be able to Update...
Oct 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    It Says "Installing Updates" but never shuts down
    If you are updating windows xp and it says installing updates when you are shutting down your computer, you should let it finish, even if it tales overnight. depenind on how many updates you have, better to go to the updates web site and do it from there. after they have installed then you should be able to do a restart on your computer and compleate. Any thing ells you are best off contacting MicroSoft
    Aug 17, 2009 | Microsoft Windows XP Home Edition English...
    My computer won't shut down it just keeps restarting
    The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
    Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
    Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
    Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
    Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
    If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
    1.
    Right-click My Computer, and then click Properties.
    2.
    Click the Advanced tab.
    3.
    Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
    4.
    Clear the Automatically restart check box, and click OK the necessary number of times.
    5.
    Restart your computer for the settings to take effect.
    Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
    Nov 04, 2008 | Computers & Internet
    I updated windows automatic updates and it kept telling me to restart the computer so i postponed it for 4 hours. i then left the computer not shutting it down correctly. now windows will not start...
    Turn on PC or restart it if it is running and keep pressing F8 during restart.
    On screen that will appear choose to start it in "Safe Mode"
    When it starts go to Start - Accessories - System tools - System restore - Restore my computer to an earlier time - choose restore point before the date and time when update was done.
    Restoring can take a lot of time so be patient even if you think that progress bar is stuck it is still working. Make sure you choose the restore point older than update time.
    Apr 10, 2008 | Computers & Internet
    Computers & Internet Logo
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
