Question about Video Game Consoles & Games
Ever since me and my family have moved from Brunei to Australia, Our Ps2's disc tray won't open, even if we press the button to open it.
    Problem Solver:
  • 9 Answers
The gear must have got damged have sony repair it.
Posted on Feb 15, 2008
Disc tray on my ps2 broke
its difficult.. but not impossible...
there r 2 push-buttons when you disamble the ps2 and u need to press them continuously in order to run your cd!
here's the solution go to youtube and search play ps2 cd's without the upper tray cover....
Jan 09, 2013 | Sony PlayStation 2 (PS2) Console
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
How to on ps2
  • Find a clear space, preferably out of direct sunlight, to set up your PlayStation 2.
  • Plug the AC adapter into the designated area on the back of the PlayStation 2 and then plug it into the wall socket.
  • Plug the RFU adapter or audio/video cords (depending on the model of your television) into the back of your PlayStation 2 and then into your television.
  • Plug your controller into the controller slot adjacent to the disc tray.
  • Plug your memory card into the memory card slot above the controller slot (see "How to Managage a PlayStation 2 Memory Card").
  • Turn your PlayStation 2 on using the on/off switch on the back of the PlayStation 2.
  • Press the eject button to open the disc tray. Insert a game disc and press the eject button again to close the tray and begin play.
  • Turn the PlayStation 2 off when done playing by either flipping the on/off switch or pressing the sleep button.
  • Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
    Tray won't close
    Use the following steps to close the disc tray on an original Xbox 360 console.
    Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
    The faceplate is the plastic piece on the front of your console.
    • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
    • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
    If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
    Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
    If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
    1. Gently move the tray up and down, and then from side to side.
    2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
    3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
    Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
    If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
    2. Press the eject button on your Xbox S 360 console.
    If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
    Dec 16, 2010 | Microsoft Xbox 360 Console
    Disc tray wont open when eject button pressed on ps2
    The disc tray motor needs to be replaced. You can find one on ebay. A relatively easy fix. Good luck!
    Nov 03, 2009 | Sony PlayStation 2 (PS2) Console
    Disc tray???
    Did you recently open the ps2/modify it?
    Found this which may help (and will void your warrenty):
    When you take the top cover off of the PS2, you can see where the Reset/Eject ribbon cable plugs into the system itself. Right next to and slightly below here are three wires with three tiny color-coded plug-ins attached. They are just pressed into place and have a tendency to work themselves out over time. And depending on which one came undone, the disc tray will either always want to stay closed or always want to stay open. Either way, the operation of the disc tray will be erratic and problematic.
    So it's a matter of using a pair of needle-nosed pliers to grasp and make sure that all three of these tiny plug-ins are fully inserted into the slots where they belong. Sometimes it's even necessary to very slightly lift the PS2 out of the bottom half of it's shell to gain better access to them. After they're all clearly in place, then it's a good idea to use the same needle-nosed pliers to make sure that the ribbon cable did not slightly pull out of place from where it is plugged in as well, or the Reset/Eject buttons will not work.
    After all this, you can put the PS2 back together and voila...you should be good to go!
    Sep 06, 2008 | Sony PlayStation 2 (PS2) Console
    Disc Tray
    The rubber band inside your PS2 might be broken, the rubber band supports the disc tray and it ejects and inserts the tray.
    Sometimes if play too much long, some of the PS2 parts will be damaged by excessive heat, so my advice is that your minimum gameplay time must be 3-4 hours only.
    Please den't even try forcing the tray to open, it will be more damaged.
    Try resting your PS2 for about 1-2 days, after that try to open the tray, if the problem still persist bring to a PS2 fixer near you.
    Jul 29, 2008 | Sony PlayStation 2 (PS2) Console
    Disk won't spin
    Have you try-d cleaning the lens with a cheep cleaner ((disk type)) some times a can of compressed air works to blow the junk out.OPENING IT YOUR SELF LAST RESORT . but if you have to ill make ya video on how to replace it.
    Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
    PS2 auto shut down when disc tray is close
    big mistake. never use ps1 cables on a ps2. i made the same mistake once.
    Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    James Wishart
    Marvin
    Marvin
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
