Question about Lenovo ThinkPad R51
Not show display clear is very darkness
Ibm laptop screen resolution is ok
  • 42 Answers
Have you increase the brightnes by Fn key and brighntess key on above of keypad please set it first fn>+brightness key
Also please check wheather the deaault settings are in agp card settings in display properties
Regards
Balisonu79
Posted on Feb 15, 2008
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
Mac
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    _
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 | bigfishgames.com
I have an IBM ThinkPad running Windows 98 Second Edition used to program older radios so it needs the older version of Windows. The display power on showing IBM Thinkpad full size, but when windows or DOS...
I've seen this before, the main problem is that the resolution is set too low, so it only fills part of the screen.
two ways to solve it.
1. Adjust the resolution to the optimal setting so it fills the entire screen.
2. Find the Picture Scaling option and have it Scale the picture to the entire screen.
To adjust the resolution, now its been a long time since I used windows 98, but I think you got to it by going to your desktop with the background, right click anywhere on the empty space and select properties, now on the window that opens it was the last page, settings I think, you should get an representation of your screen with a resolution lever and color options, pull the resolution lever one point to the right and hit apply and ok, do this until the picture fills the entire screen.
If your laptop has internet connectivity, I could take a look at it over remote support and solve the problem for you.
Oct 23, 2011 | IBM ThinkPad 380 Z (2635HGU) PC Notebook
Cannot get the Projector to see my emachines D620 Laptop screen. Press FN+F^ my computer screen goes dark but nothing shows at the projector tested the projector worked fine with other laptop
To check if the external video port on the laptop by connecting an external monitor to the laptop and see if it works. If it does work then the video port is OK and the only thing I can think of is :-
What is the highest resolution that the projector can display?
Is the video resolution on the laptop set higher than the projector's maximum resolution, if so reduce the screen resolution on the laptop.
Aug 14, 2009 | eMachines eMD620-5133 Notebook
Display problems
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 10, 2009 | Lenovo ThinkPad T61 Notebook
IBM t42 Display problem
Sometimes there are keys are your laptop that adjust your settings.
If you know which keys you can hit the fn key simultaneously.
If your not sure go on line and you should be able to find a site that will tell you how to adjust your screen.
In search type your laptop model then type display settings
Jan 12, 2009 | IBM ThinkPad T42 Notebook
Screen resolution
HAVE you tried the key Fn along with the key that marked brightness sign togehter
Nov 11, 2008 | IBM Computers & Internet
No visual display
It sounds like your graphics card is shot. If your graphics card is a dedicated graphics card, you might be able to get it fixed/replaced; if it is embedded, then you are probably going to have to buy a whole new display screen.
Sep 04, 2008 | IBM ThinkPad T40 2373 Notebook
IBM T30 LCD replaced - now LCD display not right resolution
Yes you can do that by trying to set the sesolution settting.
Step for setting up screen resolution
1.Click start-->Settings-->Conteol Panel-->Display
2.Under Display Properties window click the last tab name settings
3.Below you should be able to see Screen Resolution
4.Try to adjust the resolution here.
** Please try to reduce the resolution ...or sometime add more resolution
takecare.
Apr 29, 2008 | IBM ThinkPad T30 2366 Notebook
No visual display
Function F7 will enable the external video monitor connection and will toggle between the screen, the screen plus external monitor, and the external monitor only. Try hitting function F7 and see if that helps. Also there is a small switch that is activated when you close hte lid to turn off the display when the lid is closed. make sure that this little switch is not stuck.
Dan
Mar 21, 2008 | IBM ThinkPad T23 2647 Notebook
Hi my IBM 2635-6AU, ThinkPad 380ED 26356AU screen is dark and i cant see
From what you are stating it seems like your backlight in your lcd needs to be replaced. Plug an external monitor up to your laptop. Press the fn & f key (the one with the picture of a monitor in it.) Your diplay should project to the monitor. Display is ok.....replace the backlight.
Hope this helps you
Oct 26, 2007 | IBM ThinkPad 380ED
Computers & Internet Logo
136 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
