Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Maytag MF12568AEB refrigerator
The lights blinking de flap ice dispencer move a lot (close and open)
I disconect the conector on the top of the refrigerator no nois but is frosen the refri
i open the panel disconect cable 3 conectros work no more blink but no have water or ice
  • Anonymous Mar 24, 2014
    when opening the door more than half way at a certain spot screen blinks and inside door for ice cubes opens and closes
    Sniper:
  • 65 Answers
The high voltage control board is bad. located on rear of machine.
Posted on Feb 16, 2008
Bottom of ice dispencer freezes and wont let ice come out. It is a whirlpool side by side
Check the door flap on the freezer door , which opens to let the ice come thru . If this flap does not close completely , then it will let frost accumulate inside the ice bin , blocking ice from dispensing . If you had given the model number , I would give the part number for the door kit .
Aug 15, 2010 | Refrigerators
Whirpool side by side- opening for through door ice dispenser will not close all the way after dispencing ice. Causing condensation and loss of cool air. Any fix available?
Hi;there is a little plastic valve set up that return the ice flat. Fiddly joba and patients required so you don't brake anything else, that somethings sticks and won't allow flap to fully return. If that doesn't work, tape the flap up and open the freezer door and retrieve ice that way
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
MF12568AEB lights flashing and ice door flapping
Sounds to me the keyboard or the control panel has shorted out. If you want to get some assistance I will help you and possibly have a service manual for your model. Let me know, Thanks, Sea Breeze
Dec 22, 2009 | Maytag MFI2568AE Side by Side French Door...
Mf12568aeb lights flashing and ice door flapping
You will have to call Maytag at 1-800-688-9900...Motherboard is bad. You can pull out the little plate at the bottom of the water/ice dispenser, then unscrew the two screw. Pull on the bottom and the panel should come out. Unplug the white connector on the left. This will stop the flapping of the ice dispenser flap.
Sep 23, 2009 | Maytag MFI2568AE Side by Side French Door...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
Panel flashing, ice door opening and closing constantly
I had the same problem, with this model and it was the high voltage control board located in the rear. Replaced the board and it is working OK. Maytag Part # 12920710 will work on this model and it is 40.00 cheaper than the one it shows when you do a parts search. It will come up 12920709. I checked with Maytag and they said 710 will work..
Sep 23, 2007 | Maytag MFI2568AE Side by Side French Door...
Kenmore Elite Refig. model 54602300
problem is due to ice flap closing too quickly, depending on model some have a delay before flap closes, ice should stop falling 3 seconds before flap closes. Regards Advisor
Aug 18, 2007 | Kenmore 54602 / 54604 / 54609 Side by Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
1,085 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
