Question about Nintendo DS Lite Console
Wont stay on
I recently bought a m3ds real card and i put the software in ths microsdh card and it worked fine,but i noticed a high pitch noise coming out of the system.the console was working but i shut it off and try to put it back on and it wouldnt stay on ,it would come on and then it would shut off right away.if it does come on i cant see the top half and theres still a high pitch noise
    Problem Solver:
  • 5 Answers
Try a new battery
Posted on Feb 17, 2008
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Rattling in left earcup
Sounds like you have blown out the cone on the speaker. Have you removed the covering to see if the speaker in that earphone is intact?
Feb 10, 2014 | Bose QuietComfort 15 Headphones
High pitch noise from speakers
Hello there!
Sometimes High pitching its just that, static on the area, like if you are near a microwave, or near other electronic equipments, but, if the skreetching sound keep going or even if you do nothing it could be a line inside the sound card, or you need to clean the volume botton with special electrical cleaner. other that these, its contacts, or bad cap for the volume board inside.
Good Luck!
Carl
Apr 25, 2017 | Acer Computers & Internet
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
Numark dj io refuses to work. When plugged in it turns on then off. what could b causing this?
It sounds like a power supply/module issue. If you noticed any high-pitch hissing noise recently coming from the device, or noticed some instability in its work then these may be signs of a failing capacitor. Most probably there's one or two capacitors that serve as current stabilizers/filters, and if they break the current that leaves the power modulating assembly is not stable enough to allow the rest of the electonics to work properly. You'll need to open it and see if there are any bulged electrolytic capacitors and replace them... or have an electronics technician/TV repair tecnician to see it.
If this post was helpful and informative please give it a Thumbs Up. Thank you.
Jan 19, 2011 | Numark DJ/iO Sound Card
I recently bought a 94 3.8L V6 and the OD light started flashing. The car shifts fine. I have noticed a high pitch yet light hum, and have yet to identify the area. Fluid is fine! No burnt smells. After...
Is the car shifting? Only the light comes on? The tach should read 1800 at 60 mph in OD? I think that's right, check yours out. I have a 2000, and it has a terrible noise coming from the rear end, I don't know if it needs oil or what. I haven't gotten to it because of the weather lately.
Feb 14, 2010 | 1994 Ford Mustang
VSX 7000 doesn't come on
If you still have an issue and the unit is out of warranty , give us a call at 415.637.9989 and we will see what we can do. DAVID
Feb 14, 2009 | Polycom VSX 7000 Video Conference
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Nintendo DS Lite Console Logo
44 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
