Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
Daewoo DP42SM coloring missing blue tint on dvd playback only
I had my dvd player hooked onto daewoo DP42SM thru avi ports and they were fine {about 2 years), and then oneday the screen started going blurry while on play back. it would play fine and then blurry, and then back to fine, and then to blurry.
i thought maybe it was cables, so i changed those, and then i thought it was the dvd player, so i changed that too, and still the same problem.
my xbox 360 hooked thru component cable was fine, except that it always needed warm up time, so i hooked up the new dvd player thru component ports and the blurry lines are gone except when i turn it on it displays "no signal" on the port of rabout 10 minutes before freezing the screen; at which point i circle thru different inputs and then it comes on.
now after all that when it does come on my coloring is all screwed up. it looks as if i'm missing all colors of Blues on the screen; coloring is all red and green.
through all this the xbox screen shows no change.
any ideas?
anyone?
  • brannick Feb 18, 2008
    thank you for your info.
    where does one get all these parts?
    i'm pretty handy, but are there any soldering of prts involved in this?
  • 56 Answers
I don't know are you familiar with electronic,if you are you can fix it by yourself.The problem is in video process board,the one in metal cage.What you need to do is to remove the board from the set,remove the cage, then to replace all SMD capacitors!!!And do not put SMD as replacement put the normal capacitors same values they can be fited.You should aslo replace capacitors at the PSU and check 170V,160V and 70V and adjust them after the replacement.PSU is easy part but the video board is tricky one but it can be done
Posted on Feb 16, 2008
  • sanjin becirbegovic
    sanjin becirbegovic Feb 19, 2008
    Yes there is a lot of soldering specialy with the SMDs.Be very carefull when removing the old ones you can damage print connections and then you can only replace the whole board and its not cheep.I use two solder guns heating both legs of the capacitor at the same time.You can find pars in any electronic part shop.take a piece of paper write down the values and qty-s.I did one last week and it costed me 30euros for parts and about three hours to replace them
Hook up to dvd player
There are more than two methods of hooking up the DVD player.
1) Get a 5pin component cable with Red, Green & Blue pins. Connect the DVD Player's RGB out pins to the TV's RGB in socket. This will take care of the picture. Then for sound you will need the secondbobhifi_4.jpg set of Red & White cable. Connect the Red & White pins to the DVD players audio out socket (Red for right channel and White for Left channel ). The other end of the cable you can connect to the Red & White socket next to the RGB socket where you have connected the Video. Play a DVD and scroll through the inputs slowly. You will see the picture appear on one of your selections.
Mar 10, 2011 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Dvd color mostly blue and pink, colors look weird
try connecting thru an hdmi cable from your dvd player to your tv, check the colors then.. I'd say you have crossed your component cables.. match the connector letters a/b/x? and plug them in one after each other.
Nov 05, 2007 | Konka KDL-37AT23U Television
My sony lcd tv looks like it is missing a color, everything is green and blue what could the problem be?
What do you mean green and blue? Are you missing red? Are you hooked up through component cables? Check the component cables.
Dec 02, 2009 | Televison & Video
Tried hooking up the DVD player and get no sound & the color is really bad. I have the red, blue & green hook up am I missing something?
You have component cables from your description. Make sure that each one is in the right slot on both the DVD output and the TV input. As for the audio, the component cables do not carry audio, so you need to hook up audio out from the DVD player to audio in on the TV. Usually red and white RCA jacks for audio plugged into their respective color coordinated ports. Good luck and I hope this helps.
Oct 27, 2009 | Haier DVD101 DVD Player
Blue picture
Be sure if you are using the 3 wire video (component input) that the green blue and red wires are connected correctly on DVD player and tv. If these are switched around or all three are not connected correctly you will get an off color picture. Do not confuse SINGLE WIRE (yellow composite video) with the 3 wire coponent or progressive scan inputs .
Aug 29, 2009 | Televison & Video
How do you put Videos on The Creative Zen Mosaic MP3
well, creative zen likes avi, mpg and wmv formats
the reason that your creative zen won't read the avi is because the necessary codec is missed.
you can use iorgsoft creative zen video converter to convert the video to mp4,wmv then put them to creative zen.
http://www.iorgsoft.com/Creative-Zen-Video-Converter/
if you want to put DVD onto creative Zen, fine, you can use iOrgsoft DVD to Creative Zen converter to remove the DRM(Digital Right Management) and regional restriaction from DVD, and you can also use it to convert DVD to avi, wmv or mpg for playback on creative zen.
http://www.iorgsoft.com/DVD-to-Creative-Zen-Converter/
Jun 05, 2009 | Creative Labs Creative Technology Zen MP3...
My zen mozaic won't support any video files i put on it. what files does it take?
May 15, 2009 | Creative Labs Creative Technology Zen MP3...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Lines moving through out picture
can't give tech help ,but can tell you we have same problem and having a hard time finding an anwser /someone to come out to look . actually had a repair shop ask me to bring it in (yeah all 85 lbs.) will try calling place that repaired it when it was under extended warraunty thru best buy. took 1 mo to get the part back then. did you see my post on wiggly lines. good luck
Apr 04, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
DVD playback color
When passing the video signal thru a VCR on the way to the TV, you are activating the DVD's "Macrovision" copy protection.  You need to hook it directly to the TV.
Jan 27, 2008 | Philips DVP642 DVD Player
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
233 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
