Question about HP LaserJet 3030 All-In-One Printer
Photocopy problem the flatbed wont work for photocopying purposes, whenever I start copying, automatically the feeder of the hp laserjet 3030 tries to pick-up on something which it cant pick because the document i wanted to photocopy is actually in the flatbed area. How do I make the flatbed area work again for photocopying purposes?
  • 96 Answers
Try to check the flatbed area there's a small parts that will missing.
Posted on Jun 05, 2008
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
(HP laser jet 3030 all in one) Bad printout quality (wide black line in center) only when i used it as copy machine
Are you copying from the glass or the automatic document feeder? It sounds like you have something on the glass. Liquid paper is the most common culprit in messing up the glass. Use a good glass cleaner and a soft cloth to clear the glass surface.
Apr 25, 2011 | HP LaserJet 3030 All-In-One Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Vertical lines about one half inch apart down center of the page when fed through the document feeder. No problem with fladbed copying or scanning.
If you open to document feeder and look at the glass when scanning via flatbed, just to the left will be a smaller piece of glass. That is the glass used when scanning through the feeder. Clean that glass as there is probably a couple of spots on it.
Jun 30, 2009 | HP LaserJet 3030 All-In-One Printer
Brother MFC 9880 - When I copy a document using the flatbed feature I get several black lines or strikes at the bottom of the photocopied page. If I use the automatic feeder the photocopied page is...
Your glass is dirty. The reason you don't get it from the ADF is because it uses a smaller different glass ahead of the glass that you use when you put it on the scanner. Clean the glass using a lint free cloth and some glass cleaner or, better yet, lens cleaner.
Jun 20, 2009 | Brother MFC 9880 All-In-One Laser Printer
I have a problem with our HP3030 in that when I try to photocopy using the document feeder, the pages all come out with a double black line running down the centre of each page. The same problem comes with...
You're right. There is probably debris on the glass where the paper passes through. It's a common problem. You'll have to raise up the scanner so that you can see the glass. Then clean it off and you're back on business.
Apr 30, 2009 | HP LaserJet 3030 All-In-One Printer
ADF Usage
Put the paper in the automatic feeder. In the software options, click on ADF (automatic document feeder) and it will scan multiple pages.
Jun 06, 2008 | HP LaserJet 3030 All-In-One Printer
Scanner problem of hp laserjet 3030 all in one
Try unplugging the cord to the printer and wait a few seconds and re-plug the cord again , print what ya have to print again/hope this helps .
Dec 01, 2007 | HP ScanJet 3200C Flatbed Scanner
HP LaserJet 3030 All-In-One Printer Logo
200 people viewed this question
Ben Johnson
