Question about Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1670ASO is cycling fast and not spinning
HI,
My washer just stopped spinning and completes a whole cycle in about 3-4 minutes. It rinses and drains but doesn't spin at all.
Is this a timer issue?
Thanks,
Shawn
  • 1 more comment
  • Shawnapril Feb 17, 2008
    Leo2, Is that just the motor that is attached to the timer assembly?
  • Shawnapril Feb 23, 2008
    I found the motor controller board had a blown fuse. I tried replacing the fuse twice and it blew both times. I'm replacing the whole board next.
  • Anonymous Mar 30, 2014
    Hi, my F&P stops at last spin cycle, beeps and lights #3, #6 and #8 come on, could you tell me what the problem is so I could fix it? Thanks.
Ok guys.. Woman needs to fix washer. I took the back off and the belt is as tight as a drun skin, and looks as new as the day it was made, 10 years ago. It is a Frigidaire Gallery Model number FWTR647GHS0. The latch seems tight, but the washer drum will not turn. It does everything else, without a problem. It hums like it sould through the spin cycle, without any unusal sounds. I have checked for coins. Nothing smells "odd". (no burnt smells, or unpleasant smells, like coins leave) What is the likelihood that it is bushings or a clutch? Help! I'm ready to start beating on it with a coke bottle! :)
Posted on Apr 19, 2013
  • 125 Answers
The motor controller is the most likly suspect as it controls the timer. I would check that first. Hope this helps
Posted on Feb 23, 2008
  • benham Feb 24, 2008
    If your machine is older than 2006 the motor controller has a five year part warranty from frigidaire.
    Master:
  • 619 Answers
Hi , try to check timer small motor .,also available in appliances store.
Posted on Feb 15, 2008
  • leo2 Feb 18, 2008
    Hi , mostly of the timer are driven by small motor located attached to the timer switch, this motor are low cycle function because its reduce by gear.
Why does it stop 7 min before completing drain cycle and won't spin?
Hello Ervin, thank you for your post!
From what you have described your Frigidaire washer is stopping 7 minutes before completing the drain cycle and not spinning. This could be a possible issue with your control panel, a wiring harness, or a miscommunication with the washer. I would suggest performing a reset and you can do that by disconnecting power from it for at least ten minutes. If that does not help correct your issue you may want to seek assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful information. -Matt
Jan 23, 2016 | Frigidaire Washing Machines
Frigidaire Model # GLTF1670ASO rinse cycle is not working
ARE YOU WASHING IN COLD IF NOT YOUR WATER VALVE MAY BE BAD ONLY GIVING HOT CLOTHES WONT RINSE IN HOT
Jun 16, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidare (GLTF2940ESO) front load washer
Hi , I would like to know how to soak my whites. When it is on a full cycle Thank you
Dec 11, 2012 | Frigidaire ATF6000ES Front Load Washer
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
Washing is not draining completely. I then try to...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Frigidaire GLTF2940ES Front Load Washer
I just had a Frigidaire front load washer installed today model #GLTF2940FS1 and I am having a problem with the rinse cycle. When the wash cycle is completed and the spin cycle the machine will stop at 26...
hi thanks for the question make sure both water taps to washer are on check that because if the cold water if off it wont go into rinse cycle thanks the appliance doc
Sep 27, 2008 | Frigidaire Washing Machines
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
check you drain / drain pump... slow drain will cause a long time wash
Aug 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
526 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
