Question about Refrigerators
Leave to cool in the area of refigerador
Evaporator is tupe Frost.
    Scholar:
  • 90 Answers
If there is frost on tube going to compressor, either there is to much charge gas if recently recharged or the freezer is not defrosting as it should and needs to repaired. This usually follows with the freezer not freezing food correctly. If so the defrost timer or defrost heater coils are at fault. The timer is under the unit, the heater coils are attached to the freezer section evaporator coils which heat during the defrost cycle to thaw out the coils completely. Unplug the unit and let it defrost completely and the plug it in and see if the problem returns in the first day. If not, but returns after a day or two, then the problem is in the defrost circuit. This is not hard to figure out if you can use a volt ohm meter, but should be done by a technician since getting into the panels can be tricky....
Posted on Feb 15, 2008
Model 253.7031*. Why does it keep geting ice buildup in the freezer and not cooling in the fridge area?
Why are my fridge and freezer not cooling? - Refrigerator - iFixit
https://www.ifixit.com > Answers > View
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the ... the make an model of myfridge, so now i have that so can you please give me a ... and freezer, turn the thermostat in the refrigerator to Off, and leave the doors ...
Dec 04, 2015 | Kenmore Refrigerators
The refriderator is not cooling properly but the freezer is freezing
A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Please feel free to ask us, if you have any further queries.
Shane
Apr 24, 2011 | Whirlpool Refrigerators
I have the U-line 2015WCOL model. It was working fine and then it just quit getting cold. The light comes on but it is not cooling and the fan does not run. I cannot find a reset button anywhere. I...
Check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
Hope this helps.
Shane
Apr 24, 2011 | Refrigerators
Not cooling low enough
Hello, A refrigerator or freezer that is not cooling, but cooling poorly, may have a problem in one of several areas:
EVAPORATOR COILS or
CONDENSER
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust,lint,and dirt.
EVAPORATOR COILS:Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build up, is the presence of any frost or ice build-up on the inside walls,floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gasket.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. if one of the components in the self-defrosting system fails, the refrigerator continues to try to cool.
Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting
system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to off, and leave the doors open for 24 to 48 hours (be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually". When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat(also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor.You may need to consult with a qualified appliance repair technician to further diagnose the problem.
CONDENSER: Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt, or lint, the refrigetator may not cool properly. The coils may appear to be thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and a vacuum cleaner to clean the coils of any lint,pet hair, etc. You may not be able to get to all of the condenser from the front , it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Thanks
Jun 20, 2010 | Frigidaire FRT18FS6C Top Freezer...
Refrgerator is not cooling
Hi there
I have some stuff for you to read hope this helps you.
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | Refrigerators
I think my evaporator fan is out everything in fridge is warm to touch and ice is built up on freezer wall at rear of freezer and ice cubes will not freeze solid.also do not hear fan running any more
Hi there
I have found some stuff for you to read hope this helps you. Let me know how it goes.
Dec 27, 2009 | LG LRBN22514ST Bottom Freezer Refrigerator
Condensor line has frost on it and the fridge part isn't cold but the freezer works
Evaporator coils
Condenser
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Aug 03, 2009 | Refrigerators
Fridge-side not cold enough
Evaporator coils
Condenser
  • The defrost timer
Jul 29, 2009 | Hotpoint HSS25GDMWW Side by Side...
Frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
Evaporator coils
Condenser
  • The defrost timer
May 27, 2009 | Refrigerators
Fridge and Freezer loosing their cold
Evaporator coils
Condenser
  • The defrost timer
May 23, 2009 | Refrigerators
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
