Question about Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56 in
Anyone know how or where to find a colorwheel only P/n oc-cw7bb-bc017 or a cross referance inter change for this part.somebody makes this guy. any help would be greatful. thanks
  • lfester Feb 18, 2008
    thank for help
  • 80 Answers
If you need the origninal color wheel part #P/N oc-cw7bb-bc017
I have 4 in stock and 6 on the way. scott@palmbeachav.com
Posted on Jun 10, 2008
    Champion:
  • 206 Answers
I searched for over a month for this custmer and had no luck at all finaly the ony option was to get the light engine from Sharps board exchange for $600.00 that is beter than the 1300.00 that Andrews wanted for it. Then found that RCA used the same wheel in one of there DLP's and sure enough this part number had been discontinued and the entire set has crush and exchange order on it as well.
Posted on Feb 15, 2008
Call Scott At Palm Beach AV. He was so helpful in helping me repair my set. I know nothing about tvs, so he talked me through the howw tos and sold me the new color wheel for less than 200 dollars. He has more in stock and is very nice to deal with. I cant thank him enough. Mikemech1
Posted on Jun 11, 2008
I need just a color wheel replacement for a Sharp 56DR650 part# P/N oc-cw7bb-bc017. How much are they
A new color wheel can run anywhere from $250 to $350. You can get your current bulb and color wheel repaired for around $300. If you want it repaired, you can check this link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150548925666#vi-content
but I would definitely recommend buying a used one to replace your current one instead.
Mar 03, 2011 | Televison & Video
There is no more picture. i thought it was the bulb i replaced the bulb but still no picture or light coming out
may be the colorwheel. if the colorwheel doesn't work, the lamp won't light. if the colorwheel and the lamp are ok, replace the ballast/power supply.
Dec 13, 2009 | Sharp XR-30X Projector
Need to find a part number of a thermal fuse for a rice cooker
Check the NTE catalog of semiconductor cross reference. Look for themal fuses. Look for temprture on origina thermal fuse. Use the exact temp or the next one in line just a few degrees above. Then use the cross ref to order. Chopsticks anyone?
Aug 04, 2009 | Sharp Televison & Video
Sharp xr10x whining noise affects color sometimes not fan.
gas+heat=boom. learned that lesson myself.
sharp part # PFiLWA087WJZZ (c/w assy.)
remove the top (6 bottom screws, 4 back screws (not the one near the plug)). facing the front of the projector, the colorwheel is behind the front leveler foot and attached to the orange ribbon cable. you need to remove the lamp housing, the main board, the fan assembly between the lens and the power supply, and the lens assembly (optical engine). now remove the 2 silver screws holding the colorwheel assembly to the optical engine. that part number is for the wheel itself, so remove the 3 small screws to get it off. to install, repeat procedure. keep in mind which screws and which cables go where.
Apr 06, 2009 | Sharp XR-10X Multimedia Projector
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Color Wheel
ebay has them for like 250.00.
Jun 14, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
I have the color wheels in stock let me know if you need them
Contrast
These set have a problem with the color wheel, when it starts to fail it will do what you describe. The bad news is Sharp will not sell just the colorwheel, the sell the entire light engine for $1200.00 ond as of today I still have not found a replacment colorwheel that will work for this set
Dec 16, 2007 | Sharp 56DR650 56" Rear Projection HDTV
56DR650 Wont Turn on
I have a problem occasionally because the color wheel won't start. It has a bearing problem and is very noisy.
Nov 20, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56" Rear Projection HDTV Logo
248 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
