Question about RCA DRC8030N
Drc8030n the unit has gone to saying "hello" and will not so anything else. I have a dvd stuck in the unit and need to get it out not to mention that I have only had this unit for a year but it has become an integral part of the family. Indispencible with two children under 3
  • 1 more comment
  • aquilon Feb 16, 2008
    Same Problem here! I've had this thing about a year. Never had a problem then one day the display kept saying "HELLO" and unit does nothing else!
  • mshandler Mar 02, 2008
    there is a DVD stuck in the unit. Any ideas?
  • zitro_joe May 05, 2008
    Same problem here, "Hello" is displayed and nothing else happens...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
For DVD that are stuck. Unplug the unit from the power source. Flip open the DVD dust door (FROM TOP TO BOTTOM) now you can see the DVD disk tray. Look under it to see a white gear arm, you can push on this to unlock the tray and pull it out manually. Now you have your DVD back.
Posted on Jun 12, 2008
I NEED POWER SUPPLY BOARD FOR DRC8030N
I am sure that the fault was relative of the bad capacitor and swapping the working board has proved. Hope that solves the issue as all what is needed is to check and replace all the suspected capacitor is the Primary /Secondary side as the SMPS is working BUT with a limited voltage. So the threshold is low and so can be a tank capacitor, change the mains capacitor and also the secondary +B side.
Dec 02, 2011 | RCA DRC8030N
Drc8030n
open the DRC carefully from it back, first take out the DVD stuck in there.
After that it should work.
Feb 20, 2008 | RCA DRC8000N DVD Recorder
Won't turn on, just says "Hello" and will load no further
This is due to one of the IDE devices inside (Hard Drive or DVD drive) not sending the requires "I am Ready" signal to the main board while the DVR does a power on self test. With the hundreds of units I have come across, 99% of the time it is due to a faulty DVD drive. These "Loader" brand DVD drives were on the cheap and when they give out, the unit does not go past the Hello. You can verify this by replacing the the DVD drive with any other DVD burner or DVD drive or even a CD drive that comes from a computer (IDE connector). The only fix for this is to replace the drive or simply connect an old CD drive inside and not use the DVD properties of the DVR, only the hard disk recording/playback.
Oct 01, 2009 | RCA DRC8030N
I want to find a replacement for DRC8030N
you can replace the DVD-RW yourself with any computer DVD/DVD-rw drive.  You will need to modify the way it sits in the unit as the screw holes will be different and some drilling will most likely be needed to make new screw holes.  Finding an original replacement DVD-RW for this unit will be hard because the first problem that this unit has is a constant HELLO message due to a faulty DVD-RW, so they are in high demand.
Jan 13, 2009 | RCA DRC8030N
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Drc8030n Motherboard
Thank you so much for sending me those parts, and an extra thanks for the extras. Which happens to be what I needed to fix my problem. You won't believe it... I got your well-packaged parts today. I soon replaced the Motherboard, no change, still the same HELLO... I was so deceived... Then, I decided to replace the Power Supply, just in case... IT WORKED!... (thanks for sending me a free power supply)... Looking at my power supply, I can see that on the printed circuit under those 3 diodes, near the transformer, is an area that seems to have overheated. I will test it and give you the results eventually, as well as the results and solution if I can fix the DVD burner. I'll use the extra fan you so generously gave me to cool the power supply, seems like it won't hurt. Though I have to place it right, or it'll make the problem worse... Seems like anything wrong with this DVR and all it'll do is display HELLO... I've heard of a bad DVD Burner, a bad Motherboard and now a bad Power Supply that causes the HELLO... Thank you so very much GSAN, you did it... I recommend you to everyone out there for your fairness, kindness and devotion. We should call you Mr. FixYa!...
Nov 01, 2008 | RCA DRC8030N
RCA DRC8030N Problem
This is due to the DVD-RW drive that is in the unit. This is the first to fail and RCA seems to have gone with the lowest bidder on this model. The DVD-RW drive will need to be replaced. If you used the DVR to watch and burn DVDs then you will need to replace it with any computer DVD-RW but you may need to re-drill some holes to have the replacement drive fit exactly aligned with the DVD door. If you only want to use this DVR for the internal hard drive recording and TV viewing, then any CD or DVD computer drive will do, just simply connect the replacement drive and leave it in the case (you wont have access to the DVD or CD drive under this option). If you do replace the drive, make sure you match up the jumper on the back so that it will be in the same position as in the original DVD drive ( the Master setting). I hope I did not scare you with all this information, but unfortunately, the dreaded HELLO issue with the DRC8030N has no easy fix.
Jul 09, 2008 | RCA DRC8030N
RCA DVR SAYS HELLO
Did you try pressing the power button?
May 16, 2008 | RCA DRC8030N
Manual
my drc8030n only say "hello"
May 03, 2008 | RCA DRC8030N
Drc8030n says hello
Are all the cords connected? Is there any disk in? Make sure theese are all done
Nov 29, 2007 | RCA DRC8030N
RCA DRC8030N Logo
164 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
