Question about Texas Instruments TI-82 Calculator
Fractions How do you amke a fraction?
5ab/c +7ab/c
Posted on Oct 14, 2008
You just use the division button and it helps if you put the fraction in parenthese. So if you were trying to put in 1/4 you would enter 1 then the division button then 4. Voila!
Posted on May 15, 2008
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
Which is more precise, fractions or decimals??
Fractions can be more precise than decimals. For example: 1/3 can not be expressed exactly as a decimal. .33333333333333333333333333333333333333333... is only an approximation.
Some numbers cannot be expressed precisely as either a fraction or a decimal. pi is an example.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Jan 04, 2017 | Homework
What is the key to reduce fractions ?
The EL-501 doesn't display fractions. Some of Sharp's other calculators do, but not this one.
May 03, 2013 | Sharp El-501x Basic Scientific Calculator...
My TI 84 won't convert my imaginary numbers to fractions. I typed in 1/(1+i) and it won't convert the answer to fraction form. It keeps saying Error Data Type
The TI-84 works with real fractions. It will not convert complex numbers to fractions.
You can convert the real and imaginary components to fractions separately. For your example, 1/(1+i) is .5-.5i. Converting .5 and -.5 to fractions, you get 1/2 + (1/2)i.
Sep 15, 2011 | Texas Instruments TI-84 Plus Calculator
I CANT GET MYCALCULATOR TO DO FRACTIONS CAN YOU HOPE ME
To configure the calculator to do fractions, set the Input/Output mode to MathIO.
Press [SHIFT][MODE] to open (SetUp) then select [1:MathIO].
After you set it to MathIO, pressing the fraction key will display a fraction template where you can enter numerator and denominator as you would by hand (horizontal fraction bar). Also, the calculator will display results as fractions and radicals whenever possible.
To perform arithmetic operations on fractions use the regular operation keys (x, +, -, /). The calculator will perform the operations and display the results as fractions (whenever possible).
Aug 15, 2011 | Casio fx-300ES Calculator
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
How to convert fractions into equivalent fractions
find the least common denominator between the original fraction into the new fraction.
example, 1/2 to 2/4 to 4/8 to 8/16.
May 19, 2010 | Cycling
Pc draft fractions
if you are using MS Excel, you can type fractions by typing 0 1/2 instead of typing 1/2 only. All fractions must be preceded by 0 (zero).
Regards!
Jul 04, 2009 | Computers & Internet
How do i display fractions?
to convert decimals to fractions, type the decimal then press "math" and the first one labled >frac
*NOTE* this does not work for huge numbered fractions, like 65453434323/1000000000
Oct 29, 2008 | Texas Instruments TI-84 Plus Silver...
Fractions multiplied by fraction to get fraction
In the CATALOG there is a >Frac command that can be used with parentheses to multiply fractions.
(1/2)(1/3)>Frac
1/6
Jun 18, 2008 | Texas Instruments TI-85 Calculator
Texas Instruments TI-82 Calculator Logo
148 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
