Question about Maytag Neptune FAV6800AW Top Load Washer
Just got a New Maytag today. Filled with water and just sits there.
We checked lid seems to close ok. Has current because our old washer worked fine there. What should we do?
    Genius:
  • 3,587 Answers
Ok...so what's the issue here..is it not spinning?
Posted on Feb 15, 2008
Maytag top loader not working
check water supplys okay and lid closed properly to activate lid switch....
Jul 01, 2012 | Washing Machines
Maytag atlantis Top loading washer
it sounds like a bad lid switch.
Apr 07, 2009 | Maytag Washing Machines
Maytag washer filled with water then stopped working.
check your belts there are two of them one for the pump and the other the transmission
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
it only has one block fuse and should be located somewhere close to where the power cord comes into the washer. Go here www.repairclinic.com/SSPartDetail.aspx?s=t-LSE7806A-%3d%3di435797&PartID=435797 this is what you need to check.
Mar 02, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Washer Stopped Working
I was about to order a new lid switch assembly, but I decided to try one more thing. I disconnected the wires from the check switch and cleaned the connections - there was a layer of oxidation. The machine started right up after I reconnected the wires and plugged it back in.
Dec 17, 2008 | Washing Machines
Maytag alantis MAV 9600
hi thanks for the question re set the water level control to see if it will add more water if it doesn,t it could be a bad water valve check that thanks the appliancedoc
Sep 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Will not work
check the lid switch first, can you hear any "clicking" just before the lid is closed, try opening and closing a few times listening closely for he click, if not sounds like a bad lid switch(not recognizing the lid is closed and for safety reasons will not advance further.(far more common issue hen the timer)
Mar 24, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Checkign lid switch for maytag washer
unplug the power cable open [panel chech wiring detached /mostly some wiring detach was the line of starter switch / the water valve wiring detached / the machine will pour water if valve are malfanction insert the wire . then ok.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washer
Suem...Check your lid switch. With the lid closed, push on the atuator with a small screw driver...see if it starts agitating. Revised switch kit part number is 12001908. Catriver..post back.
Jan 26, 2007 | Maytag MAV7600 Top Load Washer
Washer will not work after filling it with water
Shawnie, sounds like your lid switch is giving you problems. They revised the switch, it comes in a kit with instructions. Part number 12001908. Take a small screw driver with the lid closed and push in on the actuator to verify that this is the problem. Catriver..post back.
Jan 25, 2007 | Maytag LAT3600A Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
29 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
