Question about Olympus WS-100 Digital Voice Recorder
Olympus WS-200S Hi. My windows xp will not speak back to me when I transfer audio files to pc. Codecs are asked for. The olympus plays back fine, so the recording is good, there. On the computer it saves as data - I just see YYYYYYYYYY cont. - it opens up in notebook. I tried opening up in Windows Media Player but it says"codecs not found" Oh yes it works/plays back very well on my friends Windows Vista :( What do you suggest please? Linda
  • lilan Mar 06, 2008
    Thanks heaps :)
  • 91 Answers
Try this solution from microsoft:
I can’t play a file that Windows Media Player supports. What should I do?Most likely, a required codec isn't installed on your computer. Typically, Windows Media Player automatically downloads any required codecs from the Internet and installs them. However, this may not happen for the following reasons:
• The necessary codec (typically, a non-Microsoft codec) isn't available on the codec server.
• You have an older version of the Player and your automatic codec-download option isn't enabled.
• The Internet security settings for your browser are set too high.
• You're not connected to the Internet.
If you have an older version of the Player (prior to Windows Media Player 9 Series), you can check your codec download setting by doing the following:
1.
In Windows Media Player, on the Tools menu, click Options, and then click the Player tab.
2.
In the Auto upgrade area, make sure Enable automatic codec download is checked, and specify how often you want the Player to check for updates.
You can change your Internet security settings (if you are logged on as an administrator or a member of the Administrators group) by doing the following:
1.
In Control Panel, open Internet Options.
2.
Click the Security tab, and then click Internet.
3.
In the Security level for this zone area, click Default Level.
If you can’t play the file after completing this procedure, restart your computer, and then try to play the file again.
If you still can’t play the file, try to play another file with the same file name extension. If you can play this file, then there is a problem with the file that you want to play. For more troubleshooting information, see the Windows Media Player Multimedia File Formats Web
Posted on Mar 03, 2008
Many video clips recorded by GZ-MG130 were stored in my old laptop (windows XP) and played well in with windows media player. 1)I have now transferred them to my new laptop ...
Hi Rajeeva.
To start try downloading updated codecs for Windows Media player, and install them onto the new laptop.
Use this link to download updated codes:Free-Codecs.com :: Download latest audio codecs
If that is not enough also update Windows Media Player on the new laptop. Link is below.
Windows Media Player 11.
Updating codecs should fix the problem already.
Jul 26, 2009 | JVC Everio GZ-MG130 Camcorder
Olympus ws-110 no playback when connected to pc
ahh...that sounds like a player issue..open your settings on WMP and look to see that it's not on sample mode
Mar 25, 2008 | Audio Players & Recorders
Instructions required for Olympus WS-200S voice recorder
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1322
Here is the link to the Olympus website where you can download a copy of the user manual
May 18, 2009 | Olympus WS-200S
Files deleted from Olympus WS-200S - Can i get them back???
Unfortunately this recorder model is designed with flash memory and once the files are erased they are gone. There are some companies that do specialize in flash memory recovery (Olympus is not one of them). You can go to google and search for flash memory recovery specialists. However this is a very costly process as it involves sending the device to these companies for them to do the recovery process.
Mar 25, 2009 | Olympus WS-200S
CANNOT TRANSFER AUDIO FILES FROM WS-100 OLYMPUS VOICE RECORDER TO PC (Windows XP)
I wrote this for the Olympus VN-3100PC although it may work with this device as well.
Try this:
This problem can typically be solved by unplugging the device from your computer's USB port and plugging it in to another USB port on the same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
Mar 04, 2009 | Olympus WS-100 Digital Voice Recorder
High pitched noise with specific file formats (WMV and WMA)
It's as simple as that, Your soundblaster is defective and requires replacement.
Jan 10, 2009 | Microsoft Windows XP Professional
How to import Olympus WS 110 audio files to computer.
Audio files need the right codecs to play them. Windows media player generally needs these to be added. Download the K-Lyte CODEC pack from the Major Geeks website. Always use the advanced mode when installing them, as they do like to change your browser settings or change your browser completely if you do the normal way.
Apr 07, 2017 | Olympus WS-110 Digital Voice Recorder
Erasing
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Sep 20, 2008 | Olympus WS-200S
Ws 200s deleted files but still full
PLAY button.
PLAY button.
Mar 20, 2008 | Olympus WS-200S
Olympus WS-100 Digital Voice Recorder Logo
129 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
