Question about Emerson EWF2004 20" TV
Tv stuck on video
Tv input button was pushed then remote was broken tv stuck on video .how can i reset with out remote
  • vvaishnav Nov 03, 2008
    cant conect my ps2 with my tv....cnt switch to a appropriate vidio mode..hav no remote for the tv
    Problem Solver:
  • 5 Answers
Posted on Feb 07, 2009
My emerson tv is stuck on video one how do i clear it
Posted on Nov 10, 2008
Try with the channel up/down on the TV or look inside the configuration menu, if your set has one.
Posted on Feb 15, 2008
New start up with an old TV
TV input is not on the coax cable input. It is likely on component in which someone renamed game chances are. (it could be any input really, hdmi, rca, or component. )
You need to change the input back to the coax, and there should be a button to do it in most cases on the tv by the power / menu buttons.
Feb 13, 2018 | Televison & Video
I have a Sharp LC-42D62U AQUOS TV. As a result of my grandchildren pushing buttons, inputs 1 and 2 are no longer available. We have followed every proceure in the operation manual to correct the problem to...
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 27, 2008 | Televison & Video
I pressed the VGA button on my remote and lost my picture.
Find the button that relates to the input you want to view. IE "video" "composite" "s-video"
Or simply try any of the input buttons until the picture returns.
Also try simply hitting the VGA button again.
If none of that works, please let me know the model number of the tv and the input sources you are trying to view.
May 02, 2008 | Televison & Video
Sanyo TV 27 inch stuck on Video mode. It reached this mode by me pressing the input button on my (GE) Universal remote, not knowing it would put it in Video mode and then accidentally pressing enter to...
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
Jan 20, 2011 | Sanyo DS31520 31" TV
My sony trinitrion always displays the video input. Who used to faed away, but is now staying on all the time. Doesn't matter if it's input 1, 2, 3, 4, etc. Turned off and unplugged but still displays all...
Using the TV's remote and having the TV on,
hold down the "reset" button and manually turn off the TV directly from the unit.(not the remote)
Release the "reset" button.
Turn the TV back on-directly from the unit.(not the remote)
A dialog box will appear on your screen.
Choose "Auto" by pushing the + on Channel Selection button on the unit (not the remote).
Use the TV/DVD selection to return to your cable input.
Jul 17, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Big Screen Problems
Try changing the channel using the buttons on the tv instead of the remote. Might work
Sep 22, 2009 | Televison & Video
All Ihaveis blue screen
You need to change the source (original remote) or the input (univeral remote). It needs to be in TV mode - not video.
Aug 30, 2008 | Sanyo DS31520 31" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Switching from video1, video2, tv
First check for a button which is stuck down (activated) on the TV & remote. I have seen a stuck button on a remote box continually sending a command to the TV. Also, try unplugging the set so the microprocessor will reset. Other contributors might have seen this exact problem, and provide an exact solution.
Sep 13, 2007 | Toshiba 32A35 32" TV
Emerson EWF2004 20" TV Logo
835 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
