Question about Janome MyLock 634D Mechanical Sewing Machine
Machine jammed the machine is new and hardly been used my wife has used this machine before with minor problems but managed to overcome them, this time when she used it the needle has jammed inside, I tried to turn the the machine manually but cant move the needle please could you advise on what to do Regards Alan and Rose
  • 3 Answers
Remove the needle plate, you should be able to spot the broken end of needle by pulling on threads jammed underneath. If you have to use something to pick it out, be gentle. You do not want to damage the mechanism. You could always try a magnet.
If you can't figure it out, take it back to retailer. As a courtesy, they are usually pretty good at helping new owners out of a "jam".
Posted on Mar 29, 2008
My machine is new (only used once) but now keeps jamming, appears the needle keeps jamming under the plate,please help.
if it' still under warrenty take it back and get another..if it's not under warrenty, try a new needle, make sure the top thread is not coming off the thread take up lever, make sure the bobbin is turned the right way in the bobbin case, also could be a timing problem
Dec 03, 2014 | Sewing Machines
Have a pfaff2036.wife was sewing and it jamed.how what
Try unplugging machine from wall. Remove the tread and needle.
Turn hand wheel backwards, the hook probably has a piece of thread jammed in the race. If you can turn backwards look for the small piece of thread remove it. New needle and rethread plug in and try again.
Oct 08, 2014 | Sewing Machines
Thread jamming in bobbin when i use walking foot
Had a similar problem with our Pfaff. Needed a replacement cam. broken gear.
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
Upper thread keeps breaking on Brother ULT 2001
the tread gets stuck on in the thread take up arm, there is a joint ware the arm is rived to gather, the thread get caught between arm and the rived sheet steel . . take little silicon gasket and fill in the joint so thr thread can't get stuck where its rived
Jan 13, 2012 | Brother ULT2001
The underside of the stitches are very loopy looks okay from the top side but the threads keeps catching underneath and jamming up the machine.
sounds like the bobbin is in backwards. Usually the bobbin thread is supposed to come off the bobbin in a counter-clockwise position going under a tension bar of somesort
May 27, 2010 | Janome Harmony 2039 Mechanical Sewing...
Thread continues to jam
Hi, my wife and I just bought a Juki HZL-E80... I love the machine. I had a problem like you discribe...This problem can come from two sources...one the bobin has been installed improperly. ...or been wound incorrectly by not haveing adjusted the Bobbin tension ...I did the tension adjustment with the screwdriver supplied with the machine accessories. Also...this is a biggie...the auto matic needle threader works great...but I discovered that when I preformed this function..that I over looked the thread holder that keeps the thread even with the needle....so, the solution is to thread the needle then be sure to check that the thread coming down from the spool is placed behind the little wire holder above the needle...I hope this helps you ...because it is a wonderful machine.....Bill & Donna Bramble...Caldwell Idaho...
May 15, 2009 | Juki HZL-E80 Computerized Sewing Machine
Needle jamming, threads all screwed up underneath, tension change
Try another authorized Husqvarna Viking dealer. Sounds like the hook/needle timing is off or the hook height. Or you could ask them to ship it back to Viking for them to do the repair. Check the Husqvarna Viking website for another dealer closest to you. You also might want to report the company to Viking. They do have to adhere to certain standards in order to keep their dealership.
Nov 21, 2008 | Husqvarna Viking 1
Machine jammed my lock 644D
Undo the needle/s at the holder screw in needle arm and gently manouver any fabric out of the way ... enough to access the screw holding the needleplate on.....very gently try to loosen & remove the needle, needleplate and fabric in one bunch.........cut threads a few inches from the jam and try to ease the whole jam away from the needles and looper, you can then sort that mess out later........
During all these processes, Do Not pull or force anything as you may bend something or throw the timing out (if it is not already out)
Once all is clear, replace only the R needle at this stage and very slowly rotate the handwheel towards you and watch the motion carefully to ensure that there are no drastic collisions of loopers and needle.
If all appears well, re-thread and do a sample test.
If things are not so rosy, you may contact me via the "contact us" page at www.bargainbox.com.au and I shall see what can be done for you to reset the timing and clearances.......if you feel up to the challenge.
Feb 15, 2008 | Janome MyLock 634D Mechanical Sewing...
Janome MyLock 634D Mechanical Sewing Machine Logo
129 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
