Question about ASUS A8N-SLI Deluxe Motherboard
Sli When i try to engage sli The sli tab in nvidia control panel says "Before you can enable SLI, all graphics cards must be installed in PCIe slots with a bandwith of x4 or greater" I have the bridge and the bios set to dual video cards. I have two XFX Geforce 8600 GT XXX"s
  • ASUS Master
  • 13,433 Answers
Hey, set the bios setting to auto. As far as I know and I have two 8600 GTs in my pc on sli I havent had to do such thing in the control panel. Directx diag reports 1008MB of videomemory for me. (both cards)
Havent had any problems myself Il test that when I get home tonight. Il provide you with more help incase I have to sort the same problem in my own pc.
Posted on Feb 15, 2008
  • Ekse Feb 17, 2008
    Seems I've been useing only one card then. I had no problems. Simply enabled the sli. I got Asus msn-sli.
    Id suggest seting bios to auto if possible.
    update your drivers or try difrent drivers
    Check asus website for a bios update.
    Try the cards in difrent pci slots, switch them around?
    I hope this helps.
How and where do you install nvidia video bridge cable asus 14010-00131200.
Hi
The video bridge cable you are referring to is I believe "Flexible NVIDIA Video SLI Bridge Connector Cable".
This is to link two graphics cards together for enhanced graphic capability, especially gaming. You would need two SLI compatible graphics cards, they should be identical, in the relevant PCIe slots on the motherboard and this cable then links them together.
If you are only using one graphics card or the onboard graphics then this linking cable is redundant.The Youtube video here:
Nvidia How To SLI Tutorial
is pretty good at showing what you need to do and where this cable goes when appropriate.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 25, 2014 | Computers & Internet
Can i add 2 graphics card in asus P5G41C-M LX ? now i have nvidia GTS 450 graphics card.. plz help.....
Hello there,
*********** board has an Integrated Intel GMA X4500 graphics, maximum shared memory of 1G, it should be automatically disabled if the pcie slot detects a video card but some mother board embedded gpu runs with the pcie card unless disabled in the bios.
Do you have plans on running a SLI (Scalable Link Interface) linking two or more gpu to produce a single output on *********** board. why SLI? because you already hae a GTS 450 GPU but you cant do this configuration because *********** board has a single pcie slot.
If you have plans on running a pci gpu with your GTS 450 it should, but if you encounter any problem try manually assigning IRQ's and resources through the BIOS? I don't have this specific board.
Hopefully this information helps.
Thanks you for using FixYa.
Sep 18, 2011 | Computers & Internet
I want to use two Graphics card in single motherboard
Not on this motherboard, and not with two different video cards. Your motherboard does have two PCI-E slots at x1 speed, but only one slot at x16 speed. And when you use SLI you should use two identical video cards for best results.
Mar 20, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
SLI
Make sure you have installed the latest Nvidia drivers. Get them from Nvidia's web site, not the included disk. Make sure "Enable SLI" is selected in Nvidia control panel. Re-seat both cards and the SLI bridge. BTW what Mobo do you have?
Jan 06, 2009 | MSI K8N Neo4 Platinum/SLI Motherboard
Computer does not boot up
Remove the second card. There is a few other things that must be done before you can select SLI & run.
Go to page 4-26 of your manual. You must set primary display adapter to PCI-E within the bios
Page 4.24 section: 4.4.4 set to AUTO. Section 4.4.5 set to High Preformance. Make sure your connecting your PCIE card in the 2 blue x16 slots & not the white x8 PCIE slot, found on page 2-20.
Happy computing & please vote.
Jan 12, 2008 | ASUS P5N32-E SLI PLUS (0610839148967)...
Second display not working
hi check for the BIOS settings for having both the cards work ..if not then try interchanging the card & slots with each other to check if one of it is faulty?
Bye Let me know
Dec 15, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
CANNOT SET UP SLI MODE
So it sounds like you are able to enable SLI mode, but once you do, you have no video output (upon reboot). The most likely problem is that it's now in SLI mode, but your monitor cable is hooked up to the wrong video card; try changing it to the other video card, and see if you have output from that one.
Sep 19, 2007 | Gigabyte GA-8N-SLI Motherboard
Sli 8600gts cards on mobo
maybe you need a higher wattage Power Supply. try decreasing the load like removing optical drives and extra HDD.
Sep 14, 2007 | Gigabyte GA-8N-SLI Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
135 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
