Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Garbled color garbled fine lines of opposite color moving like water
  • 55 Answers
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Posted on Mar 14, 2008
Mansfield toilet tank water goes down and then refills why?
It is leaking thru the flapper valve. Place a few drops of food color into tank ,later check bowl, if water is colored then it is time to replace flapper. I prefer Fluidmaster and I replace both flapper and fill valve. It is not that expensive. You can look on line or go to YouTube to get institutions on repair. Not comfortable you may have to hire someone.
Sep 11, 2017 | Home
Printer part not moving paper
Assuming that you actually mean almost the opposite, "Printer not printing or moving paper" what is it doing, please?
Neither printing at all nor moving the paper prolly means the printer isn't getting data...
Printing mixed up stuff in the same space without moving the paper means the data is garbled but gives no clue to whether the garbling is due to the printer or to the computer.
Assuming you have only one printer, does it behave exactly the same way with all documents? Does it make any difference what application made the document? Does it make any difference whether you try to print a new document or one that's previously been Saved then Closed and edited?
What happens if you try the printer's self-test routine?
After all that, one common reason for printers failing to move the paper is that rollers have become shiny with age. If that's the problem and you can reach the right roller, it might help to rough it up with something like a nail file or the striking surface from a box of matches - not safety matches; the Swan Vestas type.
Aug 21, 2016 | PRINTER Office Equipment & Supplies
I can't remember how to play chinses checkers. I have the ''very old board and all the marbles. My mind is a blank and I played it as a child....... Many years ago
Step 1 Select at least one set of 10 colored checkers (actually pegs or marbles) that correspond with the colored area of the board where they are sitting.
  • Step 2 Place the colored pegs you have chosen in the holes of the triangular area nearest to you and identify the opposite area of the board in which you will be attempting to move all of your pieces. If there are less than six players, remember to play opposite another player.
  • Step 3 Flip a coin to see who will move first, and then go around to the left.
  • Step 4 Choose your first move carefully. Just as in other strategy-based board games2_bing.gif, your first move is one of the most important. It is best to make your initial moves in a manner that will allow freedom of movement for the remainder of the pieces that are lined up behind it.
  • Step 5 Move your pieces one space at a time, in any direction, as long as it's in a line.
  • Step 6 Jump other players' pieces if there is a space open after that piece and within the same line. You can also jump your own pieces, following the same rationale. You may also jump multiple times if there are sufficient spaces available between the pieces (as in a double jump in checkers).
  • Step 7 Get all 10 of your pieces into your opponent's triangular area in order to win the game.
  • Mar 03, 2010 | NRS Wood Chinese Checkers with Marbles
    Mitsubishi dlp 52525 garbled rolling picture. Picture just colored lines, rolling slowly. Sound fine, fairly new lamp.
    You most likely have defective capacitors in your electrical chassis. It's best to send the entire chassis back to the manufacturer for total rebuilding. The cost is about $350 + labor, unless you can remove the chassis yourself.
    Good luck.
    Aug 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
    Bottom half of screen sometimes black or bad video
    Probably you have to change your resolution settings and what type of operating system are you using?? or you have to get your computer checked out by a professional to be safe.
    Apr 20, 2009 | Compaq Computers & Internet
    IBM A31 2652 Video garbled video at boot
    This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
    Feb 18, 2009 | IBM ThinkPad T42 Notebook
    update monitor driver
    your screen may be going
    how old is the system
    Jan 26, 2009 | IBM ThinkPad A31 Notebook
    Garbled sound
    Your Codec is damaged. Reload your drivers for your sound card. First uninstall the old ones. Moving your non working speakers and they play fine says they are good. I have a problem that you have new speakers and the problem went away. Drivers do not care what speakers are on the other end. It only produces output. Now that your second pair is working correctly, put back the Harmons and see if the problem comes back
    Mike
    Apr 23, 2008 | Harman Kardon SoundSticks II Computer...
    Display Problem for HP DV8230us laptop
    hi there,
    sounds like you have a driver or internal video card problem...but first have u tried changing the screen size/resolution and color depth/quality in your display settings...
    Apr 09, 2008 | HP Pavilion dv8230us Notebook
    Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
    59 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
