you don't say what windows version you are using
windows 7
Click "start" type in 'font size ' left click "make text larger or smaller "
adjust and click "apply" and "OK"
It's possible something internal failed, happens a lot due to cooling fans that quit. There's a million other things that could have caused it though, so I'd recommend sending it in for service.
thats because when u write letters and it adds letters because theirs something will be on then ur finger is big or some then it press that thing the thing will come out like when u type on one letter it will come up something
try this go to control panel from there you should be abli to change the size of your letters open control panel then click appearance and personalizaton then click display choose the make texts and other bigger or smaller
Go into the network menu of the copy machine and check the assigned "ip" address. If your copy unit is set to dhcp then all that might be wrong is that the address has changed...you print to the asigned adress that gets set up on the copyer...
More likely your settings. It maybe interlaced mode, try changing the resolution/refresh rate. there is nothing else that will cause the shaking you described.
There is another shaking that can come from the heat given off from the projector, but this sounds like a settings problem.
You will most likely need a firmware upgrade from this website to fix the problem: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
It will walk you through the steps and your letters should be back to normal after the update.
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
