Question about Averatec SDW-042 DVD RW Burner
Averetec 3200 dvd replace
How do I take out the old dvd from my averetec 3200?
  • Joe Harris Jun 22, 2008
    My Averatec boots for about 5 seconds and then shuts down, with battery in or out...thanks
    Scholar:
  • 86 Answers
If you are asking, how to manually eject a disc from a drive, I can help.
If you have a Disc stuck in the drive, you can always use a paper clip to preform a manual eject. Just unbend a paper clip, and stick it in the pin size hole on the front of the drive. Keep pushing until the drive door opens.
Posted on Feb 15, 2008
Powers up but no video
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 25, 2011 | AMD 486542-001 - HP Pavilion DV7 Series...
No drivers
use portable driver..
Jan 11, 2011 | Computers & Internet
Why my pc?while it running it goes to sleep mode and restart.?
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 09, 2010 | AMD 486542-001 - HP Pavilion DV7 Series...
I installed fresh windows on my averetec 3700 notebook, and now it won't boot up.
was the installation finished smoothly?
have you encounter any error when installing windows xp on your notebook?
if so, please post the error here and i will try to help you go on with it ^_~.
Jul 28, 2010 | Computers & Internet
I need to lighten my screen
this is not a computer problem you have to press the buttons on your monitor that is a menu when the menu comes up change the brightness
Nov 14, 2009 | Averatec 7171000100 Keyboard
How can i recieve wireless with my new windows vista?
you need a driver for it for vista. Does it show up in the device manager?
Jul 05, 2009 | Averatec 4200 Notebook
Dvd/cd-rom
what have you tried?
does it spin when you put a disk in?
have you tried using a cleaning kit?
how old is your dvd cd drive, how much usuage have you given to it? you may need to consider replacing the item.
have you installed any virtual drives? I remember dealing with an issue semilar to one described due to a virtual drive that I had installed.
if possible check the datacable.
firmware is something that you may want to update, read carefully for instructions in the manufacturer website... no garanteed that will fix any hardware issue like a faultry track that may need to be lubed, a broken motor or a faulty/dirty lense.
Nov 07, 2008 | Averatec 3200 Notebook
Averatec 3200 DCRW/DVD not working
You can put any CD/DVD/HD-DVD/Blu-Ray drive in it as long as you have the rigth connection cable and XP or above. i.e. PATA, SATA, SCSI...
Nov 16, 2007 | Averatec 3200 Notebook
Ferrari Acer 3200 Cd/DVD Drive Eject Problems
This is a hardware problem and you will need to replace the drive. The hinge screws need to be removed in order for the keypad to lift up. Under the keypad should have at least 2 screws holding the dvd rom. Remove them. If you turn over the laptop, check to see if there are any screws needing to be removed before taking out the drive. If the connection and physical size of the drive of the ferrari 3400 dvd drive is the same as this, it should work as a replacement. Make sure you check the port of the dvd drives that they are the same, as you don't want to force it and bend any pins.
Mar 17, 2007 | Acer Ferrari 3200 Notebook
Computers & Internet Logo
106 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
