Question about Sharp XV-Z2000 Multimedia Projector
Lamp timer on Sharp XV-Z2000 will not reset
After replacing lamp in projector, it works but I cannot reset timer. Followed instructions to the letter. Any suggestions?
  • 6 more comments
  • Anonymous Mar 25, 2008
    INSTALLED NEW LAMP IN THE SHARP XV-Z2000, BUT THE LAMP TIMER WOULD NOT RESET. I ALSO FOLLOWED THE INSTRUCTIONS TO A TEE - 3 TIMES. THE UNIT IS NOW BEING SERVICED AND I WILL ADVISE RESULTS.
  • shrrop Jun 02, 2008
    Thanks for the info, but unfortunately it still doesn't work. One question I had though was whether or not Needs_help99 pressed any of the buttons simultaneously or were they pressed and released before pressing the next button in the sequence.
    Thanks again for the inputs
  • cchapman Aug 09, 2008
    I have a Sharp DT-400, which I believe is identical to XV-Z2000 except for case color. I have changed the lamp and tried several times to reset the lamp timer without success. Immediately after putting in the A/C power cord, I push the "on" button (how long should I wait?), then input, then output, then left arrow, then enter, then right arrow, then on again. After pushing the output button a message comes on saying that an invalid button has been pushed, and this repeats for the next several button pushes. Finally, after 15 seconds, the yellow warning to change the lamp comes on again (the same warning I got last night that caused me to change the lamp after 95% of its lifetime).
    Is there a problem with running the projector with the lamp
    timer not reset? Will it fail to work after it gets to zero? How do I get it to reset? The authorized repairman's office is about 90 minute drive from where I live and I usually have to wait for a week to get something fixed.
  • amaurice Nov 18, 2008
    I also replaced the lamp in my xv-z2000 and could not reset the timer,I kept using it until the yellow "replace lamp indicator" turned red,then the projector switches to standby and wont turn on.Im about to send it to a repair facility
  • shrrop Jan 12, 2009
    You must do each step separately and quickly, within about one second for each step. After trying many things, this worked (solution offered by Sharp technician after three calls to Sharp)
  • rheid Feb 09, 2009
    I have this same problem, even trying the experts without help on the sharp DT-400.
    Posted by amaurice on Nov 18, 2008
    Only it is the red lamp indicator on, not the stndby light. can anyone help? the Experts can't seem too.
  • Anonymous Apr 24, 2009
    Why make this so difficult? It will not reset!
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Posted on Jan 10, 2009
REF My entry 3/25/08. I just got back my SHARP XV-Z2000 from the service organization. They did not fully specify what they did, but what was on the repair ticket was "reprogrammed" the projector. When I re-installed the projected the counter was not set back to zero. I then used the manual and followed the instructions for "resetting the lamp timer" (making sure I again followed the instructions to the tee), and the lamp timer RESET to zero. I made sure that I had a blue screen, I then selected as follows:
ON --- INPUT --- UNDO --- < --- ENTER --- > --- ON
Make sure you "depress" the left arrow < -- then ENTER -- then right arrow >. Good Luck
Posted on Mar 31, 2008
These solutions do not work for me. Any other suggestions???
Posted on Dec 07, 2013
Troutz's solution worked for me...Thanks
Posted on Apr 24, 2009
  • John Waldron Dec 15, 2012
    None of these solutions worked for me
You must do it immediately after connecting the AC power cord.
Posted on May 30, 2008
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
Reset sharp xv-100 timer
Mar 05, 2012 | Sharp (CLMPF0053DE03) Projector Lamp for...
I am replacing the bulb on my sharp xv-z2000 projector. i replaced it fine but the power light and the bulb light both stay red and i cant even turn the projector on. how do you reset the projector?
Two red lights indicate a problem with the lamp circuitry, i.e. the ballast. This requires a service center to change out a circuit board. Given the cost, it might be time to look for a new projector.
Dec 04, 2010 | Sharp XV-Z2000 Multimedia Projector
How do I reset...followed instructions but still will not turn on
Do any lights come on when you plug in the power cord? If the power and lamp lights both glow red, the problem may be in the "ballast" circuit. The projector will have to go to a service center.
Sep 26, 2010 | Sharp XV-Z2000 Multimedia Projector
Just changed the lamp in our Sharp DLP Projector, lamp indicator
You don't mention whether the power light is on as well. IF you are seeing red lights for both power and lamp, there is a problem with the circuitry, beyond just the lamp. unfortunately this is very common. The unit will likely need a new ballast circuit.
Mar 12, 2010 | Sharp XV-Z2000 Multimedia Projector
SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
Jan 12, 2010 | Sharp XR-10X Multimedia Projector
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
Sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Oct 31, 2007 | Sharp Projector lamp Projector Lamp
Sharp XV-Z2000 Multimedia Projector Logo
1,746 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
