Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Windows xp mce
Im using windows xp mce 2005 and im trying to get it to give me a live bradcast to the computer using media center and it keeps on saying not found just wondering how to get it to work on media cent if at all possable
  • 38 Answers
Do you have tv tuners installed and setup properly? Media Center 2005 is just the software, the computer needs to have hardware tuners in it and hooked up to external antenna or cable.
Posted on Jan 31, 2009
Installation of XP MCE won't finish
You need to set the pc to boot from the install disk. Then it should detect the failed install. Either select a new location or over write or format the disk and install.
Trying to recover from a failed install is usually far more trouble than its worth. You usually end up with a unreliable install and nothing but headaches.
Mar 23, 2010 | Microsoft Windows XP Media Center Edition...
Media center does not work on my windows xp
You should reinstall it using the installation cd because there is no downloads on the net for this.
Feb 22, 2010 | Microsoft Windows XP Media Center Edition...
I can no long see my dvd/cd drive anymore. Have tried every fix possible but cant bring it back! Im using a advent 7019a laptop run windows xp media center edtion 2005. Was going to try a repair but I dont...
There is a Little known problem with a certain Microsoft update that installs 2 files to the windows registry called the upper & lower filters which prevent the operation of the ODD, this can be easily rectified by removing the upper & lower filters from the registry and re-starting the machine, The problem is i cannot remeber what the link is on the Microsoft website, as i work for a large computer manufacturer i have thes details at work and will post them tomorrow. Regards Sharky P.S. you can try looking for this problem from the website and it will give you the solution to get your drive working again
Jun 04, 2009 | Computers & Internet
Windows media center on start up freezes computer, why
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
The media center is part of the WMC operative system. You can also reinstall media center alone using add remove programs, then Add remove windows components. Often that does not work, and you need to use a Windows MCE setup disk to fix the problem.
Apr 10, 2009 | Microsoft Windows XP Media Center Edition...
Is there system restore downloads to make CD for Gtwy MCE?
Well a restore CD/DVD can be created by you and kept for your use in case any crash(system) and anyway you can keep on working and save your work as we normally do. You can also create the restore CD now if you want to!............sodeep
Windows xp media center error occurs when trying to record programs
Apr 03, 2009 | Microsoft Windows XP Media Center Edition...
Corrupt files in MCE 2005 XP home
try uninstaling your windows media player then reinstaling it
it seems thers error in your media player files
hears a link 4 re download
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
hope i was helpfull
goodluck
Mar 20, 2009 | Microsoft Windows XP Media Center Edition...
Problem with window media center installation ?
Hi there
Even if you changed the computers name chances are that won't sort the problem, it sounds to me like a bad install in the first place. I would go with the re-install of the operating system.
You can call your computer whatever you want most people use their name, for example "yourname-PC".
Make sure that the disk and the lens is clean.
Good luck and thanks for using Fixya!!!
Feb 13, 2009 | HP Pavilion Media Center a1330n - AMD...
XP Media Center: Tuner Hardware not found
go into the drvice manager
right click and select scan for hardware changes
this should popup the tv tuner and automatically install the drivers..
If that fails
turn off the system
remove the tuner card
boot the system and using the device manager scan for hard ware changes
shut down
replace the tvtuner
restatr and in the device manager scan for hard ware changes again
Also in Mce insure you have the correct imaging device and tuner device selected, this will be located in the setup options
Jul 10, 2008 | Microsoft Windows XP Media Center Edition...
No video in Live/Recorded TV
  • try installing the necessary video codecs required to playi.e., based on which format your tv tuner plays,also install the software once again from your tv tuner cd
Nov 05, 2007 | Microsoft Windows XP Media Center Edition...
Televison & Video Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
