Question about Philips 25PS40S 25" TV
Closed captioning issues
I recently inherited a Phillips Model 25PS40S321 TV. I do not have a remote for this TV. The closed captioning is set and will not go away. From what I've found online, there is a CC button on the remote that controls this.
My question... is there a way to control the CC without a remote? The TV menu doesn't seem to have an option for CC. I just have a hard time believing that Phillips would only have this setting on the remote and not in the TV menu. Can someone help me turn off the CC?
  • 1 more comment
  • kelley1967 Mar 15, 2008
    I also was given a Phillips TV and I am unable to turn off CC. I don't have original remote and I am unable to use menu from tv to get rid of the CC.
  • Anonymous Feb 24, 2009
    i hate my fukkn tv its ********
  • Pillager117 May 11, 2010
    There is no PIP button on my remote. Is there some way to turn off the closed captioning without using a remote at all.
    I tried unplugging it and it didn't help at all.
Hit The PIP Button On The Remote Until It Says CC OFF
Posted on Apr 07, 2008
How do I get my color back and closed caption off my TV. I have my Phillips Magnavox TV serial number TS2544c122/ The remote to controled with our dishnet one. I need to get my color back and closed
Sounds like you might have switched display from pal to NTSC or vice versa.this is usually the first thing that causes color to drop out.if not you will need to go through menu settings to check if you have rgb or similar color controls that are not set correctly.i assume you have already checked the saturation has not been turned down.sometimes the remote buttons can stick down or be under a book or cushion which will alter tv controls without your input.
Jan 03, 2015 | Televison & Video
How can I turn off CC without remote on my Phillips Model 24PT6341/37 Flat Screen TV
Used the tv front bazel frame manual control buttons,get into the tv menu look for Colse Captioning funnctions turn off all cc to off.Very difficult to turn Close Captioning off,without a remote.Try website like Rmotes.com to buy an original remote.
Jan 08, 2011 | Philips 24PT6341 24" TV
Need to be able to turn off the closed captions on my magnavox tv. Model# 27ms4504/17 have to achieve it manually. NO REMOTE INVOLVED!
I had same problem was told by phillips that the only way to turn off is by purchasing a new remote. You can buy a universal remote but it has to have a cc button (close caption) on the remote to turn off. Purchase price for Phillips Mag remote is $26 dollars plus shipping and tax.
Jul 18, 2010 | Philips Televison & Video
How do I get the closed captioned turned off my Phillips TV?
Check the menu or display set up - highlight Closed Captioning with remote and disable, if you are using cable box - and have no success, go to the settings on the cable remote and check the closed captioning there.
Aug 02, 2009 | Philips 32PT6441/37 32" TV
Spanish closed caption, can't get to menu mode w/o original remote.
probably there is not menu button on the front panel i gess1.
  • get the original remote control at www.andrewselectronics.com if available
  • or try to get phillips universal remote control available in any retail store.
  • finally turn off those lines
Apr 15, 2009 | Philips 25PT533S 25" TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
No remote to turn off Closed Captioning
if your tv has a menu button on it enter and try ot turn it off via thr front control buttons
Apr 07, 2008 | Philips Magnavox Learning Universal Remote
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Remote Control Help
ON YOUR REMOTE CONTROL PRESS THE MENU BUTTON THEN GO TO AUDIO - CAPTIONING - OFF THIS SHOULD REMOVE THE CAPTIONING. LET ME KNOW IF I WAS ANY HELP...
Jun 21, 2007 | Jensen JER-422 Universal Remote Control
Closed captioning
try uplugging the tv for a day if the captioning is still in customer menu then try to find a universal or replacement remote this remote may have dedicated captioning key there may be a button sequence on the front of the tv that will reset the customer settings
Dec 09, 2006 | Orion STV2763 27" TV
Philips 25PS40S 25" TV Logo
332 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
