Question about Canon EOS 400D / Rebel XTi Digital Camera
No power I can't get my camera to turn on...yes I've charged, changed, etc. the battery...nothing happens. It's only 9 months old and I had just shot a birthday party the day before. Again I have changed the battery, charged the battery, etc. etc. and when I flip the switch on nothing happens....dead as a door nail!
    Novelist:
  • 130 Answers
Both your camera and the battery have a warranty, so I would call Canon and they may replace your battery out of goodwill even though it has been more than 30 days, if you provide your proof of purchase, this is always a possibility...to avoid having you have to purchase one or send camera in for service. No guarantees of course, but you should at least give it a shot.
Before doing that, remove lens, battery, memory card and date time battery which is a 3v coin battery located in your main battery compartment. It reads cr12203v on the top and you probably never knew it was there, but try to find it and slide it out gently.
Next replace the batteries and try to power on and take a shot without the lens. If this works, try adding the lens, if this works add the card and if this works, your problems are over. If it stops working at any point along the way, you know it is whatever the last thing was that you added that is causing the problem.
Either way, call Canon and their free tech support will help troubleshoot over the phone with you and set you up for service if they deem it necessary. They may ask you to send in battery and charger also to determine if there is a problem with either of those.
If you want to just try another battery, if you have time, stop by a camera store and ask if you can use the display model's battery if they have one. Most stores are ok with that.
Hope this helps!
Posted on Jun 01, 2008
How can i tell the battery on my dsc-hx9v is fully charged?
Yes! mine works the same way, when fully charged it cuts power to the battery.
Jul 15, 2012 | Sony Cyber-Shot DSC-HX9V Digital Camera
When i put the battery in my DSC-T300 the cyber shot screen comes up but nothing happens after that. The camera has never been wet, although i took it to afghanistan for a year but i kept it in its case...
Hello .Make sure battery is fully charged .Inside battery door compartment there should be a reset button to push..Try that, if unit still wont work,yes there is good chance unit was subject to moisture .Please let me know..Goodluck
Sep 23, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
Help! My Samsung PL70 which is 6months old has
Mine just did the same thing. It is frozen on and stopped working while I was trying to change the flash setting. Even the image of what I was pointing at is stuck on the screen. Mine is only about 3 months old. I tried holding down the power button and it did nothing. Taking the battery out and putting it back in worked. I hope this doesn't happen again!
Jun 07, 2010 | Samsung PL 70 SL720 Digital Camera
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
With fully charged battery 5D has power but will not take shots
This sounds like your release switch is faulty. I have repaired several of these 5D cameras with similar strange symptoms. Basically what happens is the first switch on you release assembly cracks and breaks thus making continuous contact. When this happens it basically locks up your camera. The solution is to replace the release switch assembly. The repair should not cost you more than $150.
Hope this helps.
Wes Kauffman
Jan 05, 2009 | Canon EOS-5D 12.8 Megapixel SLR Digital...
I am having some issues with my camera ..
does the unit look like it has been oponed for repair, if yes that could be your fault ...
Sep 02, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Battery Problem
If you have used this camera more than three months Try changing the battery. Before using fully charge the battery. Let the battery consumed in your camera fully then you charge again. Otherwise the battery life will reduce. Try this option before trying any other option.
Best Regards
Rafique
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Having trouble with turning it on
Try changing to rechargable batteries. I had exactly the same problem. I used recharable they run out so tried various types of alkaline batteries but the camera would not turn on. Getting the flashing green light. Charged the batteries put them back in and working again
Jan 19, 2008 | Samsung Digimax A402 Digital Camera
555 battery life problem/question
Before you conclude that my camera and battery are also misbehaving, I would point out that I have had the camera turned on a lot as I fiddled with focus, zoom, menu settings, more focus and zoom, etc, etc. There there is simply LCD viewing time to look at pictures I have taken, playing with in-camera editing features, more viewing, zooming in and out during review mode, etc, etc. Then there is downloading a few pictures at a time, which probably carries with it some USB overhead each time I connect and disconnect. So, in my opinion, I have not given the camera a fair trial of battery performance yet. Some day, I hope to go out and shoot at least a 256k memory card full of pictures before I have to recharge. Or maybe a few card's worth of photos to get that 400-600 shots per charge.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
