Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Installation on a remote iland in Panama
I bought a Fridgidaire UltraQuiet 111 for our Panama house off the grid. The plumber just put it in using the cold water supply under the kitchen sink, and it's using a lot of energy from our generator in heating Can we switch to the hot water supply instead (and use our gas demand water heater), or is this unit meant to only use cold water?
  • Peter Schild Feb 15, 2008
    Thanks, good questions Issy2. The manual was lost in transit, and we are using a portable 7.5kw kubota diesel genset. I think we'd save a lot o fuel if we uswed hot water rather than having to heat cold water first with the element.
    Master:
    Sergeant:
  • 462 Answers
Hello Sir
Posted on Feb 15, 2008
  • Mohamed Ismail
    Mohamed Ismail Feb 15, 2008
    Have you read the user manual or instruction manual, because that will insist clearly weather if we can use hot inlet or not...? Also did u mean that your supplying power to it using a portable generator...?
    Thankyou
  • Mohamed Ismail
    I would finalise by saying that u can use warm water atleast to supply in, because if the water hose used to take the water into the chamber doesnt support hot water then u will be in trouble again. But if u feel that the water hose is good enough then you can definitely send upto 70 degree celicus water into it.. So trying it once or twice will not damage ur appliance. Hoping a good rating from you..!!!
    Thankyou...!!!
My 2004 Kenmore leaks water at the water filter housing. I put a new filter in but when I wish to get water it overflows at thde top.
Fist issue, plumbers putty should not be used on any water connection for potable (drinking) water, use Teflon tale if you need to. If the leak is at the housing most likely the housing is bad, replace it.
Feb 05, 2015 | Kenmore Refrigerators
Where can I purchase a remote control for a Trevi Logical Shower?
If you cannot locate a remote control have a plumber command and we can figure the plumbing two valve so your body wash your rainshower every will work without remote is just a gimmick
Aug 09, 2014 | Home
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Is it legal to install a plumbing p trap behind a dishwasher in an exposed wall?
What are you doing? P traps stop sewer gas from coming into the house --only if there is water in them. If you are talking about putting your drain line into the P trap line, you could. You need to have a plumber see your installation to be sure.
Mar 04, 2014 | Dishwashers
Just replaced Grohe wax cartrige 47 111 000, still have slow drip. HELP! thanks, James
besides the cartridge, the small brass screw/valve and its seat can cause this leak
Dec 10, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
My past and now New currant mansfield toilet bowls do not refill with water after the third flush allowing gas to escape back into our house. My plumber is baffled and I'm afraid to purchase another brand...
If you are working with a plumber that can't answer your question, than what kind of help do you think you will get here. Not much of a plumber if you ask me, if you had problems with your first Mansfield why on earth would you purchase another, and use the same plumber??? I put a Kohler in, when I put a addition on my house and it's been working over TEN years without question and did not need a plumber to install. Take the thing back where you purchased it and exchange for an Eljer or Kohler and do not consult that braincell of a plumber, I would do it myself it's not hard go to you tube and teach yourself there are thousands of tutorials out there for doing just this DIY project.
Mar 11, 2011 | Mansfield Plumbing Products Mansfield...
Gritty/sandy feeling on dishes from dishwasher
You could only check the basics. Since the dishes are clean, it means they went through the wash cycle. It also means that that the holes on the washer arm are not blocked. If they were salty and dirty the wash arms would be something to check. And since they came out feeling like salt is on them its possible they didn't rinse and its also possible the dirty water didn't drain.Were your drain and fill hoses checked or did the techs just check the dish washing machine itself? Its also possible the water for rinse is not hot enough. Before the rinse cycle comes around try running the hot water at your kitchen faucet. Any other issues may be within the cycling of the machine.
Apr 29, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Fridgidaire UltraQuiet III dishwasher model FDB750RCC0
First thing to check is to make sure the dishwasher is getting water.
Dec 03, 2017 | Dishwashers
How to install a sink
Hi huc0,
I'm Harvey the Master Plumber.
Your problem is: You need some instructions on how to install a sink in your new house
We could set up an on line chat right here at a convenient time for both of us. I can talk you through it. It would be helpfull if you had the ability to take pictures and up load them at that time so I can see what you've got. The only sink I don't recomend for homeowner installation is a pedistal sink. They are very difficult even for a plumber.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | American Standard 0356.041.020 Lucerne...
Mira cold feed only power shower
Hi davecross,
I'm Harvey, the Master Plumber.
Your question is:
water pressure not great would a external pump help. Depends on your situation. If you live in a house with a well pump then turn up the pressure. If you have city water and the pressure is lacking then either install a house pump after the meter or if it is just the shower you're worried about then a booster pump on the shower line is the ticket. Be aware that useing the booster may reduce the pressure at the other faucets in the house while it's being used. The house pump will not exhibit this. You will likely need a local pro to help you with installation. Feel free contact me again!
Thank you, Harvey, your Master Plumber
Sep 09, 2008 | Home
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
124 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
