Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
79 harley unable to get started.
Have a 79 harley fxef, just rebuilt. Changed out the starter, selanoid, relay add electronic ignition. As per the books it should start but now joy as of yet, any ideas
  • 83fxr Jan 04, 2009
    83 shovel, POS. Just changed starter, new heavy cranking sealed batt., solenoid, bendix drive, batt. cables. All heavy duty. Tried starting it the other day (after keeping batt on trickle), very cold day. Starter, or something, Stuck. Batt got hot and bubbled inside. Disconnected batt. and took inside. Just tried again, turned once and that was it. Tried jumping w/hot box. Nothin. Now I don't even get Light from the headlight. POS is Dead, dead, dead.
    Scholar:
  • 150 Answers
Electronic ignition on a 79'? you got some mods? check for spark at the plug; check for fuel; if you got fuel/air and spark physics mandates that you will have combustion so summpin aint quite thur. stop have a coldy enjoy the way it looks for a night and start with a not so fresh mind tomorrow. oh yeah you said just rebuilt. did you paint the frame while the motor was gettin done? if you left the paint on your motor mounts on the frame BINGO! the frame to motor bolt down spot just happens to be the ground pathway for yer ignition on a 79' shovel. you can show voltage potential all day but if there isnt a ground pathway then it's only potential and not current so scuff the paint off the mount positions and try again. if this is what happened don't freak just loosen everything up lift the motor just a bit and run some emery cloth through the space. let me know if you need more details.
Posted on Apr 23, 2008
My 1996 FLHR seems to have power in the battery but wont start, horn won't blow lights wont light up, I know it has to be a tip over switch somewhere, ca
Hi, Kenny "seems" ain't gonna cut it, Mr. Electron only deals in "absolutes" and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand or clutch pull in switch/sensor.
10. Security alarm needs a reset.
11. Starter control circuit, relay, or solenoid faulty.
12. Main fuse or circuit breaker may be blown or faulty.
13. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
What to do When Your Motorcycle Won Start
http://www.carlsalter.com/pdfs/Harley%20Davidson-HD%201984-1998%20FLH-FLHT-FXR-FXSB-FXEF%20Service%20Manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak with me personally absolutely "FREE"
Mar 08, 2017 | Harley Davidson FLHR Road king Motorcycles
Points gap on an FXR Harley 1340 Evo
Are you sure this has ignition points? I don't think so.
Jun 28, 2016 | Harley Davidson Motorcycles
Starts but will not stay running
Hi Anonymous, and the usual suspects are:
1. Battery terminals loose, corroded, or broken. Check negative cable at both ends.
2. Battery nearly discharged.
3. Faulty or corroded Maxi fuse, system relay, starter relay, circuit breakers and fuses.
4. Faulty ignition coil, ignition/electronic module, CKP, CMP, MAP and BAS sensor.
5. Pin or spade connectors corroeded, melted, broken or pushed back.
6. Intermittant short circuit due to damaged wire insulation.
7. Loose or dirty ignition/electronic module at crankcase.
8. Water or dirt in carburator or fuel system.
9. Faulty fuel pump, pick up tube, pressure regulator or fuel filter.
10. Fuel tank vent system plugged or carburator vent line closed off.
For a prime suspect please visit website below:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Good luck
Mar 19, 2014 | 2006 Harley Davidson FXDBI Street Bob
Bike wont start what do I do?
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Nov 30, 2013 | 2002 Harley Davidson FXD Dyna Super Glide
1998 honda civic that wont start
You should probably have your ignition switch changed. I replaced the main relay and the fuel pump, then ignition switch. Then had to have my transmission rebuilt.
Nov 25, 2012 | 1998 Honda Civic
79 HARLEY FXEF 1200 THE TOP ROTARY DOSN'T SHIFT RIGHT
Hi Anonymous, check your shifting for spacing. Good kuck have nice day.
Feb 16, 2012 | Harley Davidson Motorcycles
We understand that your problem is: I just got my first harley, a 79 sportster, I think im having troubles with the whole ignition system, starter basically doesnt turn over at all, if anything the...
The first thing I would check is the battery. If you have a battery and no CCA then you will get this kind of issue. Load check the battery. It could have full voltage but carry dead cells and have no power to crank the motor. If the lights go dim when you push the starter button this may be the issue also check battery for corrosion and bad grounds. Check the negative cable at the battery and all ground cables to engine or frame for looseness. Let me know what happens.
Mar 02, 2011 | Harley Davidson XLH Sportster 883 Hugger...
Bike won't start. Clicking in relay. Changed relay, Solenoid and battery.
Hi Jeanders, and the usual suspects are:
3.Discharged battery, loose or corroded connections check negative cable at "BOTH" ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
7. Security alarm not disarming
For a prime suspect please visit website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Oct 05, 2010 | Harley Davidson FLHT Electra Glide...
Plugs Fowling 79 shovel
Install a Dyna, or equivalent, electronic ignition.
Jun 07, 2009 | Harley Davidson Harley-Davidson Motorcycle...
1990 1200xl sport not starting
Is the clicking noise coming from the starter? If it is I would say your bendix is shot and needs to be rebuilt.
Apr 28, 2009 | Harley Davidson XL 1200 S Sportster Sport...
Lands Phones Logo
97 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
