Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
I need a belt for my samsung dv 4006 dryer
Please advise where I could purchase a belt fot the Samsung dv4006 dryer.
gefford@nf.aibn.com
George Efford
  • 5 more comments
  • Anonymous Jun 19, 2008
    I need a belt for my samsung dv4006 as well. have you found a supplier?
  • sully1234 Sep 03, 2008
    I have DV4006 model and drum will not spin. However, hot-air is still being circulated. Would need to know were to purchase new belt and what would be involved in changing i.e. is it a do-it-yourself job or is there a skill-set required.
    Thanks,
    Kerry
  • pfinlay Nov 02, 2008
    We also had a problem gettig this belt and had to order it from Ontario. Now that we have it, my husband is having a problem getting the dryer fixed. He says that the belt seems too big, any ideas?
  • brewzer Mar 13, 2009
    Does anyone know where in BC to get these belts???
  • Anonymous May 06, 2009
    Global has it for $22.00
  • Anonymous Mar 23, 2014
    Sqeeks
    Squeeky noise
HOW DO I PUT THE DRYER BELT ON?
Posted on Aug 28, 2010
Yes!
Global electronic supplies Inc
5600 Timberlea BLVD
Mississauga ON
L4W 4M6
1-800-668-8776
Posted on Sep 24, 2008
Samsung dv4006 control panel removal
remove the top with 2 screws on the back then slide back a little then it will lift off. there are 3 or 4 tabs at the top of the console that lift and the plastic will tilt toward the front and lift off to expose the control.
Mar 14, 2014 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung dv4006 dryer heat not working
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 24, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
How do I remove a Samsung Dryer DV4006 heating element
You will NOT have to remove the drum, as the previous poster said. Unplug the dryer (VERY IMPORTANT). Undo the screws for the cover at the top right at the back of the dryer. Your element is here. Detach it from the cover plate. The undo the bottom cover plate so you can access the plug where the element attaches. You will need to reach in and manipulate the wire out of the clips (easy).
To put it back, just reverse what I've said.
Mar 10, 2010 | Dryers
Samsung dv4006 dryer belt
After four new belts.
There is only one solution , load the dryer into a UPS truck and ship it back to Samsung . Put a note inside and tell them to stick to TV's and stay out of the appliance business .This is the cheapest solution short of filling up the landfill . Believe me this is a lot cheaper than buying belts
Cam
May 15, 2009 | Samsung 7.3 Cu. Ft. Electric Dryer
I am trying to find the vent kit for a Samsung dryer
Samsung has their own Side Vent Kit which is Part Number: DV-1A. You can purchase it from samsungparts.com
May 06, 2009 | Samsung DV218AEW Electric Dryer
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung DV4006 dryer heats but does NOT turn
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like you need the belt replaced !
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 27, 2008 | Dryers
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
345 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
