Question about Adtran NetVanta 3200 Router
Can't access the internet..
Hello, I have an Adtran 3200 router connected to a T1 line with one IP address. An HP Procurve2810 switch is in the middle between the Adtran and all 7 of the office workstations trying to share the T1 (at least that what I hoped for). I can't seem to figure out how to set up the router to assign each of these workstations a unique IP address whenever it tried to connect to the internet.
I hope someone can help me out since this my first experience with T1 and I thought it would be similar to DSL.
  • 339 Answers
I believe that what you want to do is use DHCP which can assign an IP address, gateway, and DNS server addresses to computers on your network automatically. Many DSL routers include this functionality.
Normally a T1 router does not handle DHCP and the 2824 like most switches does not either. It can act as a DHCP relay but that's a feature typically used for remote locations of larger networks.
There are a couple of different ways to handle this.
1. You may be able to use your old DSL router for this role but only if it will allow you to set the gateway address to an address that doesn't match its own, i.e. the gateway address given to all clients by DHCP must be the internal address of the ADTRAN router.
2. If you have a server like MS Small Business Server then it can handle the DHCP.
3. If neither of the above are practical, you can install 3rd party DHCP server software on a PC. Here's a link to some info on doing this for windows: http://www.tomshardware.com/forum/13577-43-dhcp-server-windows Be aware that if the machine serving DHCP goes down, so will your network after a period of time.
4. I don't recommend using APIPA which is the last ditch method of automatically assigning a 169.254.0.0 network address to PCs when a DHCP server can't be found. You could make this work by giving the router an internal address on the 169.254.0,0 network but you would need to manually configure the gateway and DNS server addresses to make this work.
Regardless of how you handle this, be careful to use a private address range for your side of the router. For a network your size you would normally assign a 192.168.0.0 address with a subnet mask of 255.255.255.0
Posted on May 18, 2009
Don;t know ip adress adtran612
Maybe the user manual you can find at http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man will shed a light on your problem ?
You may try, with a computer successfully hooked up to the router, to type ipconfig /all in the Command prompt. If your router's DHCP is on, you should get it's IP address in the "Default Gateway"
May 13, 2011 | Adtran Total Access 612, T1 ATM with DSX-1...
Cisco router 1841 connected to serial interface
Make sure you set up correctly the subnet mask.
Jul 29, 2008 | Cisco (1841) Router (cisco1841)
With a /30 subnet which ip is the far-end ip address?
Generally the Highest number is the last. EG: 192.168.0.254 <<< That will be last one, first one would be 182.168.0.1.
Feb 17, 2010 | Adtran Total Access 616, T1 ATM with...
Can't connect Dell TrueMobile 1184 with Adtran NetVanta 3200
It sounds like you need to "crossover" the connection.
Using a crossover patch cable to connect the two devices is the first thing that comes to mind. (http://en.wikipedia.org/wiki/Ethernet_crossover_cable)
However, some routers/switches have physical buttons on ports to cross them over or you can use their web-based management to change port settings.
I hope this helps.
Jan 27, 2010 | Adtran NetVanta 3305 Router
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Dec 29, 2009 | Adtran NetVanta 3200 Router
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
Jan 09, 2009 | Adtran NetVanta 3200 Router
Cctv remote view/ adtran total access 900e
It's not likely that VZ gave you dynamic IP's, but it's possible. You should have been given more than one. If not, it's better to get more and a set of configuration instructions. In the last one I set up, we put a 5-port switch on the ethernet port coming off the Adtran, then fed 2 routers and a security system from the switch. Our gateway was one number lower than the bank of IP's we had, and we just gave each piece of equipment a static ip address and gateway to the gateway :-)
Carl
Sep 19, 2008 | Computers & Internet
Going wireless with a T1 Line
Going wireless should not be influenced by the nature of your internet connection. Here, I will assume that your definition of "standard router" is the kind of router we can buy at any electronic store (DLink, Linksys). I you are think more about a high end router such as a Cisco 2600 or 2800, please post a comment and I will adjust my answer.
If you already have internet access through your T1 using a wired network, you may just add one (or more) Wireless Access Points to your existing network. No need for a router here since you already have one for connecting the wired network.
On the other side, if your T1 line will be dedicated to your Wireless access, then a router should do the job. Usualy a T1 line uses a static IP address on the WAN side. If your Wireless coverage required more than one Access Points, then I would suggest you to use a standard router (no Wifi) with seperate access points.
Apr 20, 2008 | Computers & Internet
PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Jan 31, 2008 | Sony Playstation 3 (PS3) Console
Adtran NetVanta 3200 Router Logo
552 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
