Lg washer overfilling with water during first cycle
I just bought a lg washer model WM-2016-CW and during the first start it kept filling up with water then started leaking out of the door so I had to put my knee against it to keep it shut why woud it do that?
    Master:
  • 474 Answers
Becasue the water level sensor id broken or the shut off valve for the water is malfunctioning. If its brand new and has a warranty, i would take it back immediately and get a better known brand. Call the retailer you got it from and explain whats happening and make sure you pay for nothing. If you return it, they should pick it up.
Also, if the door isnt sealing tight and is leaking that means the latch is faulty or the seal is bad and that should still be covered by the Manufacturers warranty. Most things are for about 1 year from day of purchase.
Posted on Feb 15, 2008
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
Lg washer overfilling,not spinning, timer not advancing
A small tube which run up the side of the tube pushes air into a sensor which tell the machine to stop filling..Could be diconnected....Or could be a faulty inlet vave
Feb 24, 2010 | LG WM-1832C Front Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
LG WM1832CW water leaking
your valve is not closing or your cycle isn't reading correctly. there should have been a diagnostic read process that should have came with the machine. if not you may have to end up buying a new drian assembly
Jan 15, 2009 | LG WM-1832C Front Load Washer
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
Water continues filling and overflows
Tubing at bottom of tub was loose and leaking, reinstalled it and installed a clamp and it works
Dec 01, 2007 | LG WM-2432H Front Load Washer
LG Front Loading Washer overflows at detergent dispenser
you mean where you put the regular HE soap in? That slot is normal to overflow. The water carries the soap down (Lift the little doohickie up, it's removable for powder deterg.), and it carries it all the way to the tub...Unless i don't get it...but I'm reading the phrase "Its like the water will not go down to the tub.", and it makes me think the whole tray is overfilling with water..if this is the case, I can't help you, but filling over of the Main HE Soap tray is normal. (Just a little, if the whole thing starts filling uncontrollably, hit the power button.)
Feb 10, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
266 people viewed this question
Top Washing Machines Experts
