Zenith dvb410 parental control
After using my Zenith dvd player (dvb410) for 2 years, one DVD triggered a parental contol screen. I have not put any controls on the machine and have no idea how to unlock the DVD. Other DVDs seem to work fine, except for this one.
Thanks
Jean
  • 8 more comments
  • Anonymous Feb 17, 2008
    Me too!
  • frustrated64 Feb 17, 2008
    Having exactly the same problem...???
  • Nessiana Mar 02, 2008
    The exact same thing is happening to me...
  • Anonymous Mar 08, 2008
    i need the parental control code for my zenith dvb410.
    thank you.
  • gemmiti Mar 27, 2008
    whats the solution
  • Will7312 Mar 30, 2008
    After many years of trouble free service with my Zenith DVB413 I'm having trouble with 1 DVD & it's the parental control problem. It's looking for a 4 digit number to unlock it; however, I no longer have my manuel & have tried to locate one on line at Zenith's website but it's not available. Can you help?
    Please email me.
    Anthony Segraves
  • Anonymous Apr 13, 2008
    This problem just happened to me tonight as I tried to watch Across the Universe. Funny how this problem never arrived when I've watched movies MUCH for adult than this one! Tried to reset up but the reset buttom doesn't seem to work. Help!
  • Anonymous May 28, 2008
    My problem is identical to Jean Bean's; the parental control screen came up for just one disk. Guess which disc it was? "Across the Universe". I see that another write (Guest) has reported a problem with the very same DVD. That DVD only has a rating of PG13, and I have also been able to play movies with higher ratings on my Zenith. What is it about that particular DVD that triggers this problem?
    Mary
  • Babs1349 Jun 15, 2008
    Same problem and same movie as mentioned all others play just fine
  • Anonymous Jan 10, 2009
    Tried to play a DVD today and it asked for a code...I have never had to do this before and have been using the machine for 3 years
Without the DVD in the player go into your setup menu. Arrow down to the icon that is a lock press enter. arrow down to password and if it says new or change select it. you need to enter a pass code so that when the prompt comes up you can override the parental limits.
if you need to clear your old security code because you have forgotten it the manual says to input the 6 digit number from teh setup menu "210499" I did not do this as I had never set up a security code but the Across the universe DVD will play as long as enter the security code.
Posted on Sep 09, 2008
Http://www7.toshiba.com/secured/tass/technical/dvd/sd4900_svcman.pdf
This is the link to the online manual.
Posted on Mar 23, 2008
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
I inserted a DVD and the words parental control limit comes up on the screen. It's rated R but I have received many dvds from Netflix rated R which played with no problem. There is a bar with a picture...
If you are able to, go into the setup menu, select 'parental control', check the rating (8 is restricted - 1 is no restriction), and 'unlock' (if you have not set a password) then exit the setup. This should solve the issue for all future discs (parental lock is a pointless feature in DVD players, as often, owners set passwords, only to forget them later, so they cannot undo this function).
* This is for a Zenith XVB442 DVD/VCR combo, but essentially a similar setup *
If you forget your 4-digit password
If you forget your password, to clear the current password
follow the procedure below.
1 Press SETUP to display the setup menu.
2 Enter the 6-digit number 210499 and then press
ENTER.
The 4-digit password is cleared.
3 Enter a new password then OK.
I do not recommend setting parental lock passwords in DVD players, but you may not need to do this, so the above is a 'just in case'.
Apr 19, 2011 | Zenith Televison & Video
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
Can't get the Initial Settings screen
Hi,try this...with the dvd tray open,hold the rec button and play button on the dvd for 5seconds.hope this helps?
Mar 25, 2009 | Panasonic DVD-A110 DVD Player
Zenith DVB410 DVD player
I fixed it for good by sending the unit to DVD player heaven!
Jun 10, 2008 | NAD L55 DVD Player
Parental screen coming up on a DVD. Not able to watch DVD.
I have the same problem! did you find a solution to this?
Mar 28, 2008 | Zenith DVB412 DVD Player
Zenith DVD Parental Lock
Try power on the player with no disk in the drive. Press "PAUSE" on the remote. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display). Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.) . Press "PAUSE" on the remote. Power the player off and then back on
Feb 17, 2008 | Zenith DVC2200 DVD Player
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Having a problem with my car DVD player
try this code 3308 that worked for me.
Mar 04, 2007 | Farenheit DVD34 Car DVD Player
Televison & Video Logo
677 people viewed this question
Top Televison & Video Experts
Electro Med Services...
