Hitachi 50dx10b curled text around corners
Hi darklord1
I had removed and checked all capacitors in the vertical and horizontal cct. as you told me before. all of them were good as I checked with my clamp meter and no leakage found.
Then I replaced two stk 392-150 ics, two 22ohms half watts burned resistors with 1watts, another two resistors was running under 85% in the convergence panel and replaced all half watt resistors with one watts. Picture is good now except the curled around the corners. I did the fine tune but it did not make any difference.
My second question is when watching the tv from around ten feet or a less distance some light black color circles in middle of screen are very visible also when the screen is white. what is your experts opinion in this case. Thanks in advance.
Sam N
  • Sam N May 26, 2008
    Hi Darlord1
    I did well on my hitachi 50dx10b it is working fine. thanks.
    Now I wanted to replace bad convergence ics on sony kp-46c65.
    Could you help me to tell how to discharge the high voltage in this set.
    Sam N
  • 2,427 Answers
Hey sorry for the late reply,,
Usually thats a problem with the screen or filters,, I am kinda tierd up in my company at the moment and i will be more specific if you need me to.. I will contact you again as soon as i possible can,,
Sorry for my late and delaied responces but i must attend to my compays urgently need..
Posted on Feb 20, 2008
  • Rishi Roshan Ali Jul 09, 2008
    yeah no probs but i must warn these voltages are dangerous and extreme care must be taken,,
    Get an insulated flat head screw driver and a length of eletrical wire.. firmly wrap the eletrical wire around the screy driver and the other end to the metal base of the tv(what the ciurcut board is connected to.. Use the flaht head to pry the RED cap on the screen off,, ITS RED WITH A THIC WIRE ON IT CONNECTED TO THE SCREEN.. (that was highliting not shouting) enjoy and live
Mitsubishi VS-55609 top left screen has folded over
chk for any electricity or magnetic interferanc. change the location to the TV. switch of the tv fro 5 min and restart it again back.
Jul 03, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Sony KV-28FX68B (AE-6B Chassis) starts up ok. Occasional horizontal breakup/flashes but eventually vertical collapse (few minutes to few hours) & blinking standby light (4 times). Checked for dry...
Hi
Please check around vertical outpu IC for bad solder joints and you can try to replace the electolitic capacitors in vertical output line. Check if vertical plug (which comes from deflexion coils) is well attached in place.
Sully
Sep 27, 2013 | Televison & Video
Red is pulled down ,double image,top left corner, Hitachi 50dx10b hitachi
I have the same problem except my red and green are both doing it. the blue is straight but fuzzy.
Nov 09, 2010 | Hitachi Televison & Video
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
My 51' hitachi hdtv television make a clicking noice when on
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 24, 2009 | Hitachi 57F500 57" Rear Projection...
Good Evening, We have a hitachi large screen tv. It isn't a new one, approximately a 1998 model. We had been experiencing the problem of it shutting down. When we would turn it back on, everything would be...
most likely you have cold solder joints on t401 the horizontal drive tranformer. Also check that little blue capacitor in front of the horizontal output transistor.
Jan 08, 2009 | Hitachi 51F510 51" Rear Projection...
Double images
You could have some type of convergance (three colors, three guns) problem. Also a misaligned horizontal or vertical oscillator.Ceck to see if any of tiny magnets around the bell of picture tube or next to coils in and around bell of pix tube are missing.
Jul 29, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50dx10b
Try unplugging and plugging back up the power cord to reset it.
May 14, 2008 | Hitachi 50DX20B 50" Rear Projection...
Convergence Resistor Hitachi 50DX10B
2.2 ohm 1 watt...................................T.
Jan 30, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
