Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Maytag Neptune out of balance on spin cycle
By cdt1240 on Feb 15, 2008
Front load washer on spin cycle out of balance and therefore vibrates alot and makes noise. However, all vibration is internal meaning the unit is level and solid but acts as a bearing is going out or whatever controls the balance on the spin cycle is faulty. I have not taken apart yet to have a look but do you have any ideas before I dive in?
-thanks
Comments:
Feb 20, 2008
- I finally got to it and confirmed all is okay on your suggestion. Now after taking apart I found the problem in inside the drum housing which is enclosed. It is not obvious and in low spin speeds not noticable but at higher RPM's it begins to get out of balance and has a thumping noise with vibration. Do you have any suggestions? I am concerned the repair will now be labor intensive and curious if any special tools are needed to disassemble the drum unit?
Same Problem
Apr 05, 2009
-   Won't spin on small loads, out of balance all the time ....have to wring the clothes by hand then add a towel then it will spin. Just a really poor design that ties your clothes in a knot.-   Guest
Mar 11, 2009
-   I'm going put a saddle on mine and ride it!
What a POS!
Jvc-   Guest
May 29, 2008
-   Oh boy, I have the same problem. We purchased this model in Sept. 2005. The authorized repair man said $800 to repair this thing. Can you believe it - $800????? So, I called Maytag, and there is currently no warranty for this repair, and no pending class action lawsuit on this model (only on the front loading Neptune). Maytag offered me a 15% discount towards another Maytag purchase. As if!!
Perhaps we should start a similar class action claim on this model. The participants in that claim at least received some compensation.-   Sheilah20s
Apr 04, 2008
-   I had mine repaired this morning and thought the cost was really high, $429.00! He said he had to put in a new board in the back.
-   Guest
Mar 02, 2008
-   Out of balance during spin cycle. Shakes house and is very loud.-   Patty T
Best Solution
posted on Feb 15, 2008
Helpful)
leo2
Rank: Wiz
Rating: 80%, 707 votes
Hi, try to check the spring virator support might pollout from slot or hole connected, some adpter are rusted spring replace it are also available in appliances store.
Comments:
Feb 20, 2008
- Hi , the fixya repair shop near you you just enter your zip code then repair shop will attain the problem will.by the way the labor will discuss before repair.
Was this helpful?
Yes
No
Solution #2
posted on Mar 06, 2008
Not Rated)
TubeMountain
Rank: Apprentice
Rating: 0%, 0 votes
If the washer fails to drain properly it will have difficulty balancing. This causes the washer to walk across the floor. We noticed ours having a tough time starting into the spin cycle. There was noticable water remaining in the tub, visible at the very back. My wife found a quarter in the pump, about a 10 minute fix.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
would you buy that set (washer and dryer)
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
Water leaks from my Fisher and Paykel Aquasmart 8 kg washing machine - it is not coming from the... (More)
Answer
My Roper top loader will fill with water but the agitator will not spin and the drum will not spin.... (More)
Answer
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 28, 2008
I believe the problem has to do with the strut design. They are either too small or at improper angle. Maytag will not even acknowledge the possibility.
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Las Vegas, NV
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
