Question about Lanzar VIBE266 Car Audio Amplifier
Bridged lanzar amp
Can U bridge two 15in power acustics, in a sealed box, with them filp inside out and the plarity reversed, with both positivs in the right cannel and both negativs in the left channel
    Problem Solver:
  • 3 Answers
No idea, but i think you should leave the subs the right way in the box
Posted on Jun 11, 2008
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
How can i bridge all 4 channels together on my lanzar vibe 410 car audio amplifier
you cant , you can only bridge 2 channels together and what are you trying to run off the amp?
Jan 30, 2011 | Lanzar Vibe 410 Car Audio Amplifier
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
Can I hook up 2 lanzar opti1532d subs to a kicker kx 1200.1 or do I need a bigger amp, its 1ohm stable an the birth sheet says 1390 but with 14+ it does 1400rms...
Yes you Can. run them bridged parallel. meaning on the amp where the speaker wires attach there should be labeled with a "+" and "-" with a line drawn to show which terminals to hook the bridge wires up to. bridging takes power from both sides of the amp and puts it into one strong signal on half the wires. from there run your "+" wire to the first "+" on your first speaker. run your second wire from "+" on spk 1 to "+" on spk 2. repeat process from "-" on amp to "-" on first speaker and then to second speaker. __ ' a'"+"________"+"_______+ Good luck, may the force
/ ' 'm'"-" spk spk be with you!
bridged \ '__ ' '"-" ________"-"_______"-"
this will get you the most sound from the amp. if using 4 ohms speakere you will be running a 2 ohm load bridged.
Dec 23, 2010 | Lanzar OPTI1532D Car Subwoofer
I have 2 12" L7's
the kicker l7 will handle all that amp will put out .. bridge the amp and hold on
Feb 09, 2010 | Lanzar VIBE266 Car Audio Amplifier
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Wiring
In all reality, that amp is probably a bit small for those two subs. To maximize the power from the amp to the subs, make sure:
  • The dual voice coils of each sub are in parallel (+'s together, -'s together). This makes each sub 2 ohms.
  • Connect the subs in series (+ to -). This makes the combination of subs together 4 ohms.
  • Bridge the 2 channels of the amp to the subs in series (see above).
This will put somewhere between 150-200W to each sub.
Keep in mind, though, that depending on the music type and location in the vehicle, the type and size of the sub box is going to make almost as much difference as how much power is on the subs. Sealed boxes are usually small and have a nice flat response, but tend to need more power to sound louder. Ported and bandpass boxes are larger and aren't as flat of a response, but have nice loud peak at a certain frequency.
Let me know if you need any more help!
Mar 19, 2008 | Lanzar Vibe 218 Car Audio Amplifier
Amp Problems
You are probably presenting too low an impedance load to the amplifier. In bridged mode the amp must be connected to a minimum 4-ohm load. If your subwoofer is a dual voice coil type with 4-ohm voice coils, you cannot wire the voice coils in parallel and connect it to the bridged amplifier. If you have a sub with dual 2-ohm voice coils, you can wire the voice coils in series and connect it to the amplifier in bridged mode. To connect voice coils in series: Connect a wire from the negative terminal of one coil to the positive terminal on the other coil. Connect the unused positive and negative terminals to the amplifier's output.
Mar 14, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Lanzar VIBE266 Car Audio Amplifier Logo
35 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
