Question about Samsung SCX-4100 All-In-One Laser Printer
SCX 4100 Major Paper jam at rear port. Removed - won't power on
I didn't realize paper was jamming in the back. When I opened it there were a few sheets back there. I had to remove the bottom roller to get them out. I replace the roller and closed it all up and now it won't power on.
Help??
1. Check the power cord with a Tester (screw driver/circuit tester). If this is working alright go to next step.
2. Check the fuse.
Power off the printer, remove the power cord. Open the real panel, buy removing the 4 visible screws.
You would see a circuit board (infront of you). Now, on the left side, check whether the fuse is blown out. (its near the power button).
Beware, that you don't touch the coil/metal there with bare fingers, as it might give a shock!!!
If the fuse is not the problem.
3. (unlikely but still worth a check) Check that you have not dislodged any of the connectors, while trying to remove the roller.
Posted on Feb 23, 2008
Paper Jam 0 , OPEN/Close Door Message Samsung SCX4100
seems as if the motor responsible for taking in the paper has stopped working and may need to be replaced
Dec 26, 2016 | Samsung SCX-4100 All-In-One Laser Printer
Paper jam in exit area
Hi
Disconnect it completely from power and re-connect again.
Sep 16, 2012 | Samsung SCX-4300 Monochrome Laser...
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
Paper jam --samsung SCX-4828FN
i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
Sep 17, 2009 | Samsung SCX-4828FN All-In-One Laser...
PAPER JAM 2,CHECK INSIDE(SCX-4521F)
paper jam 2 is your fuser sensor error,need fuser replaced.
Jul 01, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Paper Jam 2
We had the same proplem - did you check there was no paper jammed when you opened the back cover?
Sep 09, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Printer jam 2 indication
Please make sure there is no paper left (jammed) in the printer compartment.
Remove the ink cardridge and see if any piece of paper is jammed below or behind the cardridge place.
If there is a cancel button press it several times.
Switch off the printer and let it for a few minutes and then turn it on.
if nothing of the above worked please ask me again
Thank you
Aug 25, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Paper jam error, check everything but still showing paper jam
turn off the printer
Unplug it
open the paper jam door and gently push the paper roller forward until it clicks.
close the door
wait a few minutes
plug the printer back in
turn it on and see what happens.
I hope this helps.
Aug 18, 2008 | Samsung SCX-4725FN All-In-One Laser...
Paper Jam Error 2
Don't try a dozen things suggested by people online who's credentials are unknown. Go straight to the source.
I had the same issue and just went to www.samsung.com - looked up my model #, downloaded the PDF manual 86 pages and did a search for that error. It had step by step picture diagram of how to clear out the jam.
I just saved the company a few hundred on a service call to our printer sales/service vender.
Oct 28, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
91 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
