Question about JVC GR-D370 Mini DV Digital Camcorder
How do I clear SafeGuard error mode off camcorder? eeror o6
I have removed the battery from the camcorder for a day and it's been unplugged for two days and I still get the safe guard mode error, how do I clear this?
It says remove and reattach battery and plug, I do this for a day and it still says this?
Thanks in advanced for your help!
JVC GR D370U
  • robertwiley Feb 15, 2008
    What do I clean the heads with? By heads I assume you mean where the battery is attached and where the dc plug attacheson the camera?
  • robertwiley Feb 16, 2008
    I'm very frustrated, I put new battery in safe guard error is still present, how do I reset the camera, is there a way to reset the error?
    I have not cleaned the heads yet.
    I really need to get this fixed, thanks!
    Guru:
  • 1,894 Answers
Hello
Posted on Feb 15, 2008
  • 2 more comments
  • dewan nafees ahmed Feb 15, 2008
    here you go
    >>then please try replacing the batteries by a new one or a spare battery you have.
    >>if camera remains hanged up like this then you will have to reset it i think.
    >>if you have a service manual it will be more useful for you..
    dont forget to rate the solutions
    thank you
    good luck
    >>clean the contacts for the battery and the those on the camera.
    >>also try the AC adapter and still the same safe mode message comes means proceed
    >>this will be a battery issue
    >>now if leave using the camcorder for some time and then error message will get cleared and then the camcorder will tell you that u need to clean the heads
    hope this fixes you
    thank you
    good luck
    no no sir. please dont clean it with hands.
    there is a special procedure.
    there is a special tape which is available at many shops. these is only used to clean the heads.
    but other than head you can clean everything with a soft sponge.. head must not be touched like that.
    please dont forget to rate the solution too
  • dewan nafees ahmed Feb 16, 2008
    i dont think resetting will be a very good option..
    first try all the solutions given above
    thank you
    good luck
SOURCE:
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Playback moe
Could be a DEW sensor. It could cost about $90 - $116 to replace that sensor
Dec 31, 2008 | JVC COMPACT VHS-C CAMCORDER
Please help
You most likely have bad capacitors in the camcorder. Not a really hard fix except you need special surface mounted soldering tools, a service manual and a service wire extention kit. Very expensive these days to repair. There are a few Camcorder repair shops that charge a flat rate. You can look up camcorder repair up on the Internet and find them, or I will send you some if you need. In my opinion, it is time to retire the old girl and find a shiny new digital camcorder. They are not all that expensive these days. Good Luck
Mar 21, 2008 | JVC GR-AXM710 Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Error Code
remove and reattach the battery
Sep 29, 2007 | Video Cameras
JVC GR-D370 Mini DV Digital Camcorder Logo
335 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
