Question about Sony PlayStation Portable (PSP) Console
Psp recovery menu comes up as soon as i switch on then when i manage to load a game all controls are in differnt places and game freezes plus volume is set at high and will only go off,pleasepleaseplease help.............
    Problem Solver:
  • 6 Answers
Try reinstall the custom firmware you are using with a pandora Battery :)
Posted on Feb 18, 2008
Tip
Play psp games on tv via composite/component av cable
you will need to have:
1.a psp slim with custom firmware 3.80 or 3.90.
2.composite/component av cable.
3.installer plugin file FUSA that can be sourced in the internet e.g. qj.net.
4.memory stick pro duo with 2 gigabytes capacity.
steps:
1.source the FUSA installer file.
2.once sourced,extract it to your pc desktop using 'winrar'.
3.connect pc to psp via usb.
4.upon extraction,copy or drag all four files (prx and txt) to the 'seplugins' folder on the memory stick (ms0:/seplugins/).
5.if you don't have the 'seplugins' folder on the root of the memory stick,create it.
6.exit usb connection and completely turn off psp,then turn it back on while pressing the 'R' button to go to recovery menu.
7.on recovery menu,choose and click plugins,set the FUSA plugin to 'enable',then exit recovery menu.
8.you can also activate the plugin on the FUSA menu itself,and this is better recommended.
9.connect now psp to crt tv using component av cable.
10.load a game and after loading it,just right before clicking the 'start' button to begin play,exactly at this point,simultaneously press on the volume - and + buttons to bring out the FUSA menu.
11.after a few seconds,the FUSA menu will appear on the psp screen,change the settings accordingly,exit FUSA menu and start the game to play it on your tv.
*many games or emulators will work but not all as the FUSA file is still in its beta stage,you need to figure out which one will work or not through trial and error.use caution,this guide works but no guarantees.
*used a 2 gb memory stick pro duo as 4 gb didn't work.
*used on an interlace only tv and not progressive or crt/non-flat/lcd/plastma/hdtv's.
thanks.
on May 05, 2008 | Sony PlayStation Portable (PSP) Console
When i try to run a iso/cso game, the white psp would shoe up and then the screen truns black went back to the psp menu and it said Game could not start 80020148 my psp's system software is 5.00 M33-4
What you need to do is disable the umd from within the custom firmware menu. Completely turn off the PSP (hold the power button up until it turns off). Then while holding the right shoulder button, turn the PSP on. The recovery menu will load. Select configuration and then disable the "no umd" option. Exit from the recovery menu and insert a umd disc into the PSP. Make sure auto start is also disabled in the PSP menu settings. You should now be able to run your game.
Hope this helps and thank you for using FixYa
Jan 06, 2011 | Sony PlayStation Portable (PSP) Console
When psp freezes what we should do
  • disable plugins: go to the recovery menu by holding R when psp is starting up and then going to advanced>plugin and in this u can disable them
  • Is it freezes if your psp boots without any UMD? Can you go around in and out the options on the main menu? If not, your PSP broke. You need to send it for services or repair.
    Did you downgrade/upgrade? What version?
  • Reformat your memory stick and reload all your games
May 30, 2010 | Sony PlayStation Portable (PSP) Slim...
Psp won't load a game from memory stick. tried to reformat the memory stick but still the same result. Music, videos and images are working well. tried to use 8GB, 4GB and 2 GB still the same issue.
what u need to is go to ur recovery menu by pressing select and reset and than hold R trigger till it comes back on. now ur in the recovery menu now go to configuration scroll down were u see load from umd and chang it to load from memory card and exit and play it
Jul 06, 2009 | Sony PlayStation Portable (PSP) Console
Cannot play games and can't go to recovery menu
To be honest my friend you would have been better off going to 5.00 M33-6, There's no direct solution but it's probably best to have a look around this following website!
http://pspupdates.qj.net/
May 25, 2009 | Sony PlayStation Portable (PSP) Console
Psp star wars edition freezes up, loads games very slowly
my soloution is to take it back to the store to fix it or do u have a warent if so u can trade your psp for a nother on
Dec 28, 2008 | Sony PlayStation Portable (PSP) Console
Help please...
PRESS R TRIGGER WHEN YOU SWITCH ON YOUR PSP A RECOVERY MENU WILL BE DISPLAYED THEN GO TO TOGGLE USB AND CONNECT YOUR DATA CABLE AND IN YOUR XCOMPUTER YOU WILL SEE A REMOVABLE DISK WILL COME AND OPEN IT AND GO TO GAME FOLDER AND MAKE A FOLDER NAMED RECOVERY AND PASTE SONY OFFICAL 1.5 FW IN IT AND THEN GO TO RECOVERY MENU
May 12, 2008 | Sony PlayStation Portable (PSP) Console
PSP Problem
I dont know how technical savvy you are but there are several DIY guides on the internet to replace the UMD drive which often fails on the PSP.
Check out this website for a complete tutorial.
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
you can find hte UMD parts on ebay usually as well
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=psp+umd+drive&category0=
If not type in google psp repair.. there are plenty of place that do repairs.
Apr 29, 2008 | Sony PlayStation Portable (PSP) Console
Psp wont load any games or do anything bdoes come on to menu
Simply dead laser , search on ebay for the part and look for guides on google or service it to sony
Dec 06, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
