Question about SanDisk Sansa e250 MP3 Player
My mp3 how to switch to recoevery mode
  • 54 Answers
Ok first plug it into your computer, then push the hold button over so the orange is showing. next push and hold the record and power button. (try to push them down at the same time) it will work if you do it right guarenteed.
Posted on Feb 15, 2008
GC-822 Buttons Just Change the Color
After a mode is selcted by moving the mode slider switch left or right then depress that same mode slider switch like a button. When the mode switch is used to change a mode but one does not press it in to select it, that is when the play button changes colors.
Sep 20, 2009 | Sears GC-820 MP3 Player
Need to mp3 out of mtp mode and into usb mode need help
in the manual it says Turn on the MP3 Player by holding the PLAY/PAUSE button. 2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer. 3. When connected the LCD Display will either say “USB” or “MTP”. 4. Press the “M” (mode) button to switch between “USB” and “MTP” mode. “MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5 is this helpful.Take your time sometimes these things don't work because you've missed out one step so go slow and try it two or three times before you give up
Aug 29, 2009 | GPX MW3837 MP3 Player
SONG ONLY PLAYS FOR 30-40 SECONDS
pure,
Most probably you accidentally switch the play mode to " INTRO" check your display if it does indicate Letter " I" in it. if does any music you play will be in "INTRO" mode. IF you still have the manual for your player check the 'PLAY MODE" setting. From this setting you can choose play mode from "FOLDER" "NORMAL" "INTRO""REPEAT 1" REPEAT ALL" to play in continuously select "NORMAL" mode.
I'm not sure if your player do have the same procedure in changing play mode . But try this , while on play mode . Press menu and a dialogue box will appear scroll and select "NORMAL"
cheers,
mark
Feb 04, 2009 | GPX MW3836 MP3 Player
Problem with mp3
You can switch your player between USB and MTP mode only if your player is connected to Windows XP machine and Windows Media Player 10. When the player is connected to your Windows XP machine, pressing the M button on your player will switch your player between USB and MTP mode.
-Tha Mp3 Doctor
Sep 18, 2008 | GPX MW3836 MP3 Player
Sansa e250 mp3 player
remove ur batery and replace it or download the file archieve.exe and install audible folder.then u can switch on it.
Jul 03, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database fail
Hi try this for me see if you can put your mp3 into recovery mode if it goes into recovery mode then i tell you what you need to do next ok follow these instructions
1. with mp3 off switch lock button to on position
2. press and hold rec button on left hand side
3 whilst holding down rec button switch mp3 on this should now be in recovery mode let me know if you get this far ok
Feb 23, 2008 | SanDisk Sansa e250 MP3 Player
Switch to recovery mode...
go here
good luck
please mark the post with a fixya!
Feb 12, 2008 | SanDisk Sansa E280 MP3 Player
Usb disk
the mp3 player can be switched from mpt mode to usb mode. You probably have it accidentally switched to usb mode. This allows you to drag and drop music files to it but you wont be able to make the best use of the music software that comes with it.
It is not a problem. There is a setting in the player that allows it to switch back to mpt mode
Dec 31, 2007 | Samsung YP-K3 MP3 Player
MW3837 MP3 PLAYER
push the mtp mode button
Dec 20, 2007 | GPX MW3837 MP3 Player
Mp3 player has no music
The player has a Recorder Mode and an MP3 mode. The player defaults to recorder mode for some reason, this is probably why you cannot see the songs. To switch to MP3 mode you have to hold down the MODE button for more than 2 seconds. Then you should be able to see the songs.
Apr 23, 2007 | Sony NW-E507 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
15 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
