Question about Refrigerators
Freezing in Fridge
I have a LG refrigerator (Freshmaster No Frost GR 242mf) The freezer section is on the top, It is about 5yrs old It is freezing everything in the fridge section, I have tried all positions on the thermostat control to no avail, I originally had water leaking from fridge department onto floor,
  • Gerry69 Feb 18, 2008
    It doesnt matter which way I turn the the thermostat in the fridge dept, The compressor runs all the time, But when I adjust the thermostat control in the freezer dept down low it turns off,I havent had time to look at anything else at present but I will keep you posted, And thanks very much for your help anyhow, Regards Gerry 69
    Scholar:
  • 90 Answers
Does the compressor run continually? Will it turn off when the thermostat is turned all the way down?. If it runs all the time it is possible the defrost timer is not working. It is located under the unit where the water tray is. Along one side or even at the front there will be a black plastic box with a shaft coming out that with a flat tip screw driver can be turned only one direction. Try turning it slowly to see if the compressor shuts off. Also mark the shafts position and see if it has changed after a few hours. It should. If not it is bad. If the unit doesn't shut off when the thermostat is lowered all the way, it could be the problem.... Start with the defrost timer first...
Posted on Feb 15, 2008
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
GE GSHF6KGZBCBB
first check to ensure the fan is blowing while compressor is running ..is there frost build up in the freezer? ge is known for having bad therms
Jan 10, 2014 | Refrigerators
My fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
My fridge makes loud popping noises and is over cold (freezing the things in the fridge & frosting up the freezer, when it is a frost free freezer)
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Sep 11, 2006 | LG LRTN19320 Top Freezer Refrigerator
Refrigerators Logo
395 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
