Konica 7020 Printer
The Konica 7020 has service error in the display, I have used a key stroke sequence to reset the unit guided by a Konica tech but cannot find the key sequence to reset I previously used and the tech has moved on without new contact details.
Konica wont sent a service tech as I dont have a contract and they want to replace the printer can you help service request
  • 2 more comments
  • Instro Feb 25, 2008
    Please call service
    F-36-2
  • Karl1960 Feb 27, 2008
    I repaired a problem and the error code F-35-8 is still up. How do I reset the copier?
  • cinge May 19, 2008
    how to key stroke sequence to reset
  • yoder10 Dec 07, 2008
    The machine was serviced not to long ago and will not allow me to make copies without contacting a service rep. Please help!
    Sniper:
  • 153 Answers
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Posted on Apr 01, 2009
How to reset code 35-3 on photocopier konica 7020
DO THIS once because you are re-setting the FUSER it can catch on fire that will ruin a perfectly good day!!!!! Get a tech out to look at it.
Turn on the main and sub power switches.
Keep pressing the * button until the message
"Please enter service password." appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press 2 and 5 to select 25 mode. Then select soft switch. Set 3, then set 1 then change 1 to 0. to clear the code.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 13, 2014 | Konica Minolta Konica 7020 W/fax Kit...
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
How we reset printer konica minolta 1390
About 88,000 results (0.73 seconds) Search Results
    [PDF]PagePro1380/1390 MF Service Manual - Printers - Konica ...
    printer.konicaminolta.net/drivers/other/1390/1380_90_fs.pdf
    the risk of damage to the product, KONICA MINOLTA BUSINESS TECHNOLOGIES, INC. (hereafter called the KMBT) strongly recommends that all servicing be ...Missing: we
    [PDF]PagePro 1390 MF Printer / Copier / Scanner User's Guide
    images10.newegg.com/User-Manual/User_Manual_28-117-006.pdf
    PagePro is a trademark or registered trademark of KONICA MINOLTA. PRINTING .... Print Media 20. What Sizes of Media Can I Use? 20 .... Stop/Reset key. Exits the menu. ... Right-click the KONICA MINOLTA PagePro 1390 MF printer icon.
    [PDF]Technical Guide - Printers - Konica Minolta
Feb 12, 2014 | Konica Minolta PagePro 1380 MF Laser...
KONICA 7020 ERROR F26-2
You'll probably need to call a tech & have him Clean the sensor in the drum unit, chances are thats why you had faded copies in the 1st place,that sensor works with the tds sensor in the dv unit to add toner,good luck
Jul 24, 2012 | Office Equipment & Supplies
When I turn it on it starts to ware up and I get an error message engine panic
Can you give me the exact brand and model number of your multi-function printer?
What is the exact error message that it gets?
Any additional information will help us in resolving this issue.
Thank you!
Apr 07, 2010 | Konica Minolta PagePro 1390MF All-In-One...
F-35-4 this is over problem
Fuser error: lamp, thermistor, fuse problem, etc. Part needs to be replaced and code reset in service mode only. Call a tech
Jun 20, 2009 | Konica Minolta DiALTA Di200 Copier
Hi there!!! My printer displays error message: malfunction detected call representative - c3751. Kind regards
hi this is a high temp code, you need to replace the fixing unit then get a service tech to reset the machine
si
Jun 05, 2009 | Konica Minolta bizhub C250 All-In-One...
Paper jam
I strongly recommend a service tech. It sounds like you will need a PM kit,fuser claws and a few DFP rollers.
Mar 21, 2009 | Konica Minolta DiALTA Di200 Copier
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
1,044 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
