Question about Maytag Atlantis MDG6400AW Gas Dryer
Need help quick
Dryer doesn't heat.
  • Sandra Feb 15, 2008
    Thank you so much for such a timely response. It was very much appreciated. I will try replacing the glowbar (hopefully the part is readily available) and let you know if it works.
    President:
  • 1,314 Answers
You proably need to replace the glowbar or safty selonoids glow bar is number 1
Posted on Feb 15, 2008
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Our dryer doesn't dry clothes like it should, sometimes takes a long long time and other times quick and the clothes feel really hot, model # is DLE 2532W
see this causes and fix it. God bless you
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating element is easy to replace. Check our videos for other types of dryer heating elements.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and easy to replace.
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Sep 27, 2012 | LG DLE2532W Electric Dryer
My dryer mod rex5634kq1 stopped working
what stopped? Does it not Spin? if so it could need a new motor. If it spins but doesn't heat up. it could just be a heat sensor in the back that needs to be replaced or a heating element. if nothing happens at all it could be the start button needs to be replaced. Turn the dryer around and open up the top back panel. should be about 6 screws. inside there will be a diagram on the schematics of the dryer.
Hope this helps.
Mar 27, 2012 | Roper REX5635E Dryer
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 11, 2011 | Dryers
Dryer will not heat but will run.
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 10, 2009 | Whirlpool LER5636P Electric Dryer
My Dryer Will Not Warm Up Or Heat Up At All!!!
May 05, 2009 | Dryers
Maytag Atlantis MDG6400AW Gas Dryer Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
