Question about Brother HL-2040 Laser Printer
Streaks on paper after new drum installed
Put new drum in and streaks just changed places and density, not disappear.
You must clean the corona wire unit by sliding the blue tab right to left several times. make shure you return the tab to the home position arrow to arrow.
Posted on Feb 23, 2008
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
I have a 7820N. I put in a new drum in January and have printed a few hundred pages. Put in a new toner cartridge after i started getting lines and streaks on the paper. They come and go but are getting...
Hi There,
When you installed your new drum did you reset the drum by.
1 - Opening the front cover.
2 - Press the options button up on the panel.
3 - Press 1 to reset
4 - Close the front cover done.
If the issue persists after resetting your drum contact brother technical support you may have a defective drum unit.
Thanks,
Viper1969
Mar 03, 2010 | Brother MFC-7820N All-In-One Laser Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Brother mfc. I made the mistake to use canned air to clean copier which got into my drum and made black streaks on my paper I keep cleaning the black streaks off the drum but when i put it back in i have...
First clean the glass of the laser.If you open the front door remove the drum from the machine just above were the drum was in place there is a glass mounted.Try and make a test print.If the streaks is still printing and you can see the streaks is deffinately from the drum you can strip the drum,clean the corrona wire and grit,and clean the drum brush.Strip only the drum unit if you sure the lines is caused by the drum.
Dec 11, 2009 | Office Equipment & Supplies
Our Trusty steed HP 8500 has just started to print a thin twin line and other spurious marks on the top side of prints. Today i replaced the drum / fuser / other bits but no difference any ideas?
I have looked at the manual but there are so many possibilites! You can download the manual here and go to page 148 (PRINTING QUALITY PROBLEMS).
Initially I would follow the directions for clearing drum related errors:
Dark or white lines or streaks in all colors, including black.
Print the configuration page five times. The defect should clear
with continued printing. If the defect does not clear, turn the
printer off and on to reset the printer’s density calibration. If the
problem persists, replace the imaging drum. For more
information on replacing the imaging drum, see the installation
guide included with the drum kit.
Then clean the density sensor.
To clean the density sensor
Open the upper right door.
2 Use the brush located next to the
sensor to remove all toner particles
from the sensor.
Note
You can also use a hand wipe to clean the
density sensor. To prevent scratches on
the sensor, do not use any paper products,
such as tissue or paper towels, to clean the
sensor.
3 Close the upper right door.
It could possibly be a problem with the transfer drum.
I am sorry this is not of much help!
Nov 13, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
When printing backgroud is grey
Causes
Print density setting.
soluitons
The print density may be set too high. Try adjusting the print
density. For details refer to the printer's operation guide.
Causes
Defective drum surface potential.
soluitons
If a drum unit which is known to work normally is available for
check, replace the current drum unit in the printer with the normal one. If the symptom disappears, replace the drum unit with a new one
Causes
Defective main charger unit.
soluitons
Replace the main charger unit
Causes
Defective developing roller (developer
unit).
soluitons
If a developer unit which is known to work normally is available for check, replace the current developer unit in the printer with the normal one. If the symptom disappears, replace the developern unit with a new one
check ifyou want service maual you can send mail to anantakumarjena0@gmail.com
Oct 30, 2009 | Kyocera FS-2000D Laser Printer
Konica di620 ghosting and streaking
What about the starter/developer last time its been changed? Upper fuser/fixing roller (Hot rollers) don't forget to clear counters once those parts are installed.
Aug 05, 2009 | Sharp AL 1631 Copier
Grey background and dark streaks
Change out the toner first and then the drum. Also be sure there is not excess toner underneath where the toner is installed. If so clean that out with a dry cloth.
Apr 18, 2008 | Brother HL-2070N Laser Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother HL-2040 Laser Printer Logo
395 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
