Speakers inop. on kenwood reciever
My speakers suddenly stopped working, ive checked the internal fuse, wire connections,are there other possibilities. i have a kenwood integrated reciever/tuner
  • 1,512 Answers
The speaker protection circuit sounds to be engaged. This protects you speakers form damage if a fault condition occurs inside the amp. Generally speaking, unless you have good experience at fault finding electronics, then this may be a job for a repair guy. If you want to know more about diagnosing the problem, get back to me here. Good luck :)
regards
Graeme
Posted on Feb 15, 2008
Power on, clock works, CD works, NO SOUND from the radio
Check the speaker wires maybe they have worked loose. And speakers themselves as they may blown. Do you have an amp if so check its fuse. Also check for inoperative interior lights, lighter, and horn. One of these circuits will power the radio's memory circuit. Some radio models will appear to work normally but have no sound if the memory fuse is blown. The clue is the clock will reset to 12:00 each time you turn on the ignition switch.
Feb 12, 2017 | Cars & Trucks
Ive had my speaker for a week and it stopped working suddenly. Ive had it plugged in to recharge but the light is not blinking yes Ive confirmed outlet is working etc.
A bit more information is needed but here is a couple of thing to try. If these are wireless then make sure the send/receive unit is properly seated. If these are amplified speakers (speaker has the amp built in) then check the fuse for them. If these are wired speakers then you need to check the connecters.
Feb 08, 2016 | Audio Players & Recorders
I have a Kenwood kr-v8010 and all a suddenly one channel is only working just woundering if its a easy fix?
Could be a speaker wiring issue, defective speaker or possibly a speaker protection fuse inside the unit has blown.
1. Check speaker wires for proper connection.
2. Swap left and right speakers to see if the problem follows the speaker.
3. Check for internal speaker fuse that may have blown. PLEASE proceed with caution inside the unit. With the AC cord unplugged there are still high voltages resident inside...BE CAREFUL!!
Oct 31, 2012 | Audio Players & Recorders
My altect lansing bxr1121 speakers stopped working suddenly. I have checked all the connection but the power led is off.
Hi. i think it is the internal connections or jacks need to be resoldered, but first try to check the continuity of each wires. tact switch cleaning and replacement is another approach.
Mar 07, 2011 | Altec Lansing BXR1121 2 Speakers
MY KDC-MP3342U SUDDENLY STOPPED WORKING! IT JUST KEEPS FLASHING ...'PROTECT'! REPEATEDLY! HELP!
Protect only comes on when an RCA is grounding out, speaker is blown or the speaker wires are shorting out. Check all your wiring on the head unit and see if all are insulated with tape or better and if there's an exposed wire, tape it up. Make sure that all connections are secured. Then double-check your fuses. Check all of your speakers and their wiring because going into protect mode is the units way of saying you have a problem with your speakers or wiring.
If your speakers and wiring all check out, disconnect your radio wiring harness, and then reconnect the harness. This resets your radio, and your radio should be working again.
If you need to enter the security code, try the default unlock code of 5227.
You can also try to reset your code if the default doesn't work. Try 'KCAR' or '3051'.
Jul 12, 2010 | Kenwood Car Audio & Video
Kenwood VR-410 Reciever cuts out at high volume
Very possibly a problem with overdriving the speakers and the breaker inside the receiver is "popping" in order to protect the outputs from being fried. check the ohm rating of the receiver to the speakers and lok for damage to any of your speaker wires. also make sure the wires are not crossed or touching in the back connections to the equiptment.
Dec 12, 2009 | Kenwood VR-410 Receiver
Turns on then shuts off like it has a bad fuse
HI...
Check to see that all the speakers are firmly connected at BOTH ends.
Also,if the receiver has speaker select switches, see if turning off the speakers allows it to stay on.
Let me know , Thanks
Feb 08, 2009 | Kenwood Audio Players & Recorders
Factory Stereo
My stereo system for my 2005 Altima Nissan stopped working and wouldn't eject the CD. The CD has been removed but the CD player doesn't work and want take CD'S. The radio continues to work.
Oct 01, 2008 | 2005 Nissan Altima
Sounds problem
First things to check:
  1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
  2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
  3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
Mar 13, 2008 | Directed 1100d Car Audio Amplifier
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
150 people viewed this question
 Grubhead
Grubhead
