Question about Brother MFC 210C All-In-One InkJet Printer
Brother printer MFC 210C
My printer don't print and cannot remove the pause on the printer
David
dodorp43do@yahoo.com
  • 2 more comments
  • JoJo777 Feb 22, 2008
    I got a new Dell computer and my brother printer don't work.
  • jennkate1 Sep 02, 2008
    error message "unable to print"
    I have checked and there is no paper jam
    There are no faxes
    I have shut down and unplugged
    after several minutes when I turn printer on I again get same message "unable to print"
  • drugo Oct 11, 2008
    hi I have a similar problem. Magenta was nearly empty. Now the priter will not print"Unable to Print" on monitor. Tried all neccessary points on manual, no luck. chaged the magenta but still nothing. Ink monitor on pc still show magenta nearly empty. When i try to clean the printer beeps several times but nothing happens. Any help please?
  • jay2646 Dec 03, 2008
    Mfc 210c on/off button don't work stays on all the time. Paper jam message but there is no paper jammed in the machine. Troubleshooting and routine maintenance instuructions in the user guide is useless. what to do next?
  • 4 Answers
I was getting a constant "Paper Jam" message, even though I thought I had cleared the jam. If you are having this problem, go to this site:
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000400/000095/faq000495_002.html?reg=eu&c=gb&lang=en&prod=mfc210c_all&Cat=4
I didn't realize there was a removable cover on the back of the printer. I took it off, and sure enough there was a small triangle of paper approximately 1/2" on a side jammed in one corner. Earlier, when I removed the larger piece of paper, I had not noticed the missing corner. Fixed the problem!
Posted on Oct 06, 2008
Ok el error 46 o unable to clean en las impresoras brother se debe a que llegaste al numero maximo de purgas de cartuchos por lo cual la impresora supone que el wasteink o el deposito donde tira la tinta esta lleno y para evitar que se tire y te haga un desorden monumental recomienda que lo cambies asi por lo cual se sugiere que si no quieres comprar uno nuevo abre la impresora y cambia la esponja.
cuando el contador de limpieza llega a 6400 se genera un error interno machine error 46. asi que las futuras operaciones de limpieza son prohibidas and la impresora no se puede usar
Pero no te espantes ya que tiene arreglo.
Como Reseteando ese famoso contador
como ok
no te voy a complicar
primero daz click en menu/set
y presionas *2864
pero ojo ojo esto lo tienes que hacer todo en menos de 2 segundos
como sabras si funciono si funciono al menos en este modelo mfc 210c empiezan a parparear los botones photo capture copy fax y scan
eso es que si funciono si no funciono presiona stop y vuelve a empezar recuerda menos de 2 segundos
y en la pantalla dira maintenance
ahora el codigo para mantenimiento es 80 presionas 8 y seguido el 0
dira la hora y al final ok
ahora presiona el boton black start son segun las conte como 24 veces te va diciendo datos de la impresora el que nos interesa dice purge:06400
ya estando ahi metemos el codigo 2783 y se pone en 0
ahora presionas el boton stop para regresar al menu anterior dira maintenance y ahi presionas 9 una o dos veces dira please wait hace un reinicio prende y lista para usarse nuevamente
posteado por SYSTEC DURANGO
soporte@tododurango.com email/msn
www.tododurango.com/soporte
Posted on Feb 26, 2008
Como reseteo una brother 115c ??
Posted on Aug 22, 2008
Can't turn on mirror printing to print an iron on transfer
You need to make the changes in the drivers. Click on start then control panel, double click the printer icon. Right click the MFC-210c and select printing prefferences. Click on the advanced tab and put a check mark where it says mirror printing.
Apr 21, 2010 | Brother MFC 210C All-In-One InkJet Printer
All of sudden I can not print on my MFC 210C multifunction printer. Where is the USB suppose to be plugged in?
Hi
I have put 2 PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Brother-MFC-210C-Users-Guide.pdf
Click Link= http://www.4all2sell.com/pdf/Brother-MFC-210C-FaxGuide.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 07, 2010 | Brother MFC 210C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Cannot print
go here for online PDF version of manual for MFC-210C from www.brother.com
http://www.brother-usa.com/Support/Default.aspx?WT.cg_n=Support
Mar 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
UNABLE TO PRINT BROTHER MFC 210C
Go to this link and find Page 11-4 in the section on Troubleshooting:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Let me know if this has helped you to solve the problem. Binary Bob
Dec 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C Printing slow
You may have already tried but /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} From page 129 of the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Changing the printer driver setting may improve the print speed.
Highest resolution needs longer data processing, transfer and printing
time. Try the other settings of quality in the printer driver ‘Basic’ tab.
Also, click the ‘Settings’ tab, and make sure you uncheck the
True2Life®.
Borderless printing is slower than normal printing. If you want to print
more quickly, set the Borderless feature off.
Aug 30, 2008 | Brother MFC 210C All-In-One InkJet Printer
Mfc 210
if the MFC is a brother..your print head could be dead.
Jun 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc 210c printer
Difficult solution !
http://www.fixya.com/support/t258155-remove_print_head
Jan 12, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
857 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
