Question about Intel Desktop Board D845GERG2 Motherboard
Connecting Speaker can you tell me where to locate internal speaker pins? Manual is pretty useless in terms of clear illustration..??! Tim - UK
Look for a 4 pin connection point near the other front panel controls.
It should look like:
The "square" is the pin 1, the speaker is connected between the pin 1 and 4.
Posted on Feb 15, 2008
    Problem Solver:
  • 23 Answers
Dear Big Timmo,
To connect the Speaker Pins u have to check left or right side of u r mother board where u r power wire, reset wire and Hard disk led wire connected to the mother board. it has 12 or 13 male pins. There u will find in writen speaker in the motherboard. I hope now u can connect u r speaker pins..
Regards,
Bittu_8
Installing an internal speaker on a Desk top pc mother board do you need to reconfigure your system.
Typically, the speaker is connected with 2 or 3 wires. The connector block should have a pin labled "SPKR" or "Speaker". From there, count three up and find a pin labeled "+5v". These two pins are typically separated by two ground pins.
So, the connection would be: spkr, gnd, gnd, +5v. The ground pins may, or may not be used depending on your design.
Nov 06, 2014 | Computers & Internet
Hello! I have got GA-7VAX rev1.1 motherboard, but the embedded (internal) front speaker is disconnected. Can you, please, tell / show me the right pins to connect speaker to ?
Go to the Gigabyte website
http://www.gigabyte.com/support-downloads/download-center.aspx
and enter the motherboard number GA-7VAX
and you can download the manual which shows what the pins are.
Apr 25, 2011 | Gigabyte GA-7VAX Motherboard
Monitor Speakers are working however I can not adjust the volume to a level I can hear (I am not deaf) I have gone to the control panel and increase the settings there but still unable to hear ir clearly....
The speakers for the monitor are low rated in terms of required power input. You can open the speaker box and disconnect one from the two wires connecting the speaker and leaving the other one still connected direct to speaker.
provide a resistor from a range of 25000 to 30000kilo ohms and connect the chosen resistor between the wire which was cut on the speaker. this way you will provide what we call attenuation on the path. please check and try this method. thanks for asking fixya.
thanks.
Jan 06, 2010 | ViewSonic VA1930WM LCD Monitor
Factory bose speakers wont run on a normal stereo
Im sorry to tell you, but they are telling you the true. Unless you have the factory Radio that comes with those speaker they are useless to you unless your car is the same make as the one that those speaker came out of. Each speaker have four wires coming form them? If they have only two wires on them you can use them in series with other in your home theather system.
Nov 01, 2009 | Car Audio & Video
I'm looking for manual i need JPN1 setting pin outs for power switch, speaker, etc
hello, look at the motherboard clearly or you put it under light, you will see all the jumper pins labeled with or printed with white paint, the name of each connection pins is written on the board. the speaker is far from the power switch,the reset pin is by the side of the power pin, the HDD light and the power light are opposite each other.to make things simpler, i suggest you forget about the reset and other ones and concentrate on the power pin. bridge all the pin with a screw driver to locate for the power pin i.e two pin at a time.
Aug 06, 2009 | Soltek SL-75FRN2-L Motherboard
Connecting ouverture to penta 3 active loud speakers
what are the speaker connections for left and right out put on the Beosound ouverture tape cd player.   there are 2 x 8 pin din sockets on the back what are the pin numbers?
mick55kennedy@gmail.com
Apr 08, 2009 | Bang and Olufsen Beosound 2000 Shelf...
There is an inbuilt speaker but the sound is not coming
Hi gogovie_2,
There is only one speaker controller (C-Media 8738-MX), built into the P4B533 motherboard which is where you would connect a home speaker system into the lime green port located at the rear of the motherboard. (See your manual, page 1-7 for the motherboard layout & location of the line out jack for your speaker plug). See pages 1-8, 1-9 & page 1-10 for descriptions of each item shown on page 1-7.
The ASUS P4B533 MB usually comes with a small black speaker that plugs onto the motherboard. You can see the location for this speaker on page 2-33. Number 18 shows the configurations for the 20-pin panel & internal speaker.
This tiny speaker is used for system P.O.S.T. Known as Power On Self Test. During the boot up process a single beep will sound off. This tells you that the motherboard bios has passed P.O.S.T.
If you need the manual for the ASUS P4B533 motherboard you can download it directly from Asus. Click on the link below. Once the link has loaded type the model number, P4B533 in the search window (Upper right hand corner) & click the white arrow.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Click on, " P4B533 related files for download ". The next window will want you to click the dropdown menu & choose your operating system. (Do so). Asus will display all drivers, manual & bios files for the P4B533 motherboard. If you download the manual you'll need Adobe reader to view the manual. You can download Adobe for free at this next link; http://www.adobe.com/products/reader/
If you do not have sound from your home speaker system make sure you have installed SoundMax/C-Media software. This program uses jack auto detecting censer software to help setup your speaker (s). You can also download the latest audio drivers.
If you think you need a new (Internal speaker) you can buy one from here; http://www.pcpartscollection.com/mosp.html
& from here;
http://www.anitec.ca/product/11692/generic_4_pin_speaker_for_motherboards/
Lastly, if the information provided here has not answered your question, please rephrase your question. I'm sure I can provide you with an answer & fix.
Mike
Feb 03, 2009 | ASUS P4B533 Motherboard
Where do you get the speaker connectors and wires
As an alternative cheap solution, if you have the following available you can do as I've done.
I used an old burnt out ATX power supply 24pin motherboard connector, cut all the wires of about 10 inches and then cross sliced the connector up into 2pin connector pieces. Worked perfect, saved me $ and made some great recycling use of an otherwise useless PSU.
Nov 18, 2008 | Yamaha DVR-S120 DVD Player
Swapped mother board
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Nov 02, 2008 | Asrock 775VM800 Motherboard
Intel Desktop Board D845GERG2 Motherboard Logo
261 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
